Author Topic: problem  (Read 3843 times)
Offline Lukas692
problem
« on: October 25, 2016, 10:45:14 am »
My ULib/ULX versions are fresh downloaded
DarkRP
here a picture of my console :/
(its 100% sure ulx/ulib got nothing else on my server at addons)
Re: problem
« Reply #1 on: October 25, 2016, 01:00:55 pm »
Umm... What exactly is your issue? Are you trying to run this command? Because that looks incredibly fishy.
If you're trying to run that with malicious intent, I have no intention of helping. If you're seeing this in your console, your server seems to be compromised, and you should shut it down and do damage control immediately to determine the cause.
Check everything—lua, addons, etc. Your client, even. Do a fresh install of Garry's Mod dedicated server and make sure something deeper isn't compromised. Make sure to change your rcon password, or disable it if it isn't essential.
« Last Edit: October 25, 2016, 01:02:54 pm by Bytewave »
Re: problem
« Reply #2 on: October 25, 2016, 07:04:02 pm »
You have an exploit, or at least attempt of one.
I searched Google for xn--vxao.pw and found this
https://facepunch.com/showthread.php?t=1521418&p=50474888
No clue what put it there, as this discussion mentions several things that might have put code there.
If you got ULib and ULX from ulyssesmod.net, our Steam Workshop, or our Github repo, it's not from us.
If you got it from anywhere else, it's possible someone else modified our code (NEVER get it from non-official release links)
