Author Topic: I keep crashing  (Read 9986 times)
Offline Dr_cheese
I keep crashing
« on: October 29, 2016, 08:40:52 pm »
so i keep getting this error
 [ERROR] lua/autorun/sh_legs.lua:371: attempt to call method 'InVehicle' (a nil value)
  1. fn - lua/autorun/sh_legs.lua:371
   2. unknown - addons/ulib/lua/ulib/shared/hook.lua:110
And it crashes me every 5 minutes from my server, i highly doubt its an addon and ive run virus scans, can someone help me out
Re: I keep crashing
« Reply #1 on: October 29, 2016, 09:12:52 pm »
Your issue is with whatever addon you've added or subscribed to that has something with "legs", per the sh_legs file mentioned.
Likely this one I found using Google searching for "Gmod sh_legs.lua InVehicle"
https://steamcommunity.com/sharedfiles/filedetails/?id=112806637
That release is over 4 years old. It's likely not compatible with newer Gmod.
Whether you subscribed or downloaded one like it, it's not our product causing the issue.
Remove that old one.
Offline Dr_cheese
Re: I keep crashing
« Reply #2 on: November 12, 2016, 03:47:40 pm »
It happens (to only yourself) when you are burned while ragdolled via !ragdoll (running on ulx and ulib on latest versions).
Re: I keep crashing
« Reply #3 on: November 12, 2016, 04:16:03 pm »
What are you burning ragdolls with?
Re: I keep crashing
« Reply #4 on: November 12, 2016, 05:51:42 pm »
Megiddo, no matter what he's burning himself with, if he's getting the same error and same crash, the legs addon is crashing him.
I could easily imagine that, if you're dead, player can't be valid, and therefore, can't be InVehicle.
If he removed/had Legs repaired, and are now getting a different error, then by all means, we need to know.
Offline Dr_cheese
Re: I keep crashing
« Reply #5 on: November 18, 2016, 08:01:26 pm »
I have a TTT server, and on any map while player is ragdolled via !ragdoll (not killed) and is burned, the player receives the error and immediately crashes. Nothing was done to the legs/removed. Same error still applies
Re: I keep crashing
« Reply #6 on: November 18, 2016, 09:06:57 pm »
If you removed the legs addon, you wouldn't be getting the same legs error.
