Author Topic: New Group Cant Use Ulx Commands  (Read 13677 times)
Alden
« on: October 31, 2016, 09:16:35 pm »
ULib v2.61
ULX v3.71
Game mode(s) I am having this problem on: WW2RP NutScript
Lua errors shown in console, if any: Nope
I made a new group (moderator) and they can't use ulx commands such as /plytransfer or /doorsetfaction. I've tried matching it with the same abilities of admin and they still cannot use their abilities. Admin ranks and above work perfectly fine, its quite frankly odd. Is it because of a conflicting issue with NS? I need some help tackling this problem and getting this rank working.
Thanks in Advance,
Alden
Offline Caustic Soda-Senpai
    • Steam Page
Re: New Group Cant Use Ulx Commands
« Reply #1 on: November 01, 2016, 12:21:19 am »
Did you give this moderator group access to those commands?
« Reply #2 on: November 01, 2016, 02:42:16 am »
I believe this would be an FAdmin problem and not a ULX problem. Check the permissions you gave them to make sure. Other than that I don't think I can help much.
« Reply #3 on: November 01, 2016, 03:04:41 pm »
iViscosity is correct in that those are not ULX commands, so you'd need to figure out what permission string FAdmin uses for those.
Alden
« Reply #4 on: November 02, 2016, 06:44:12 pm »
Edit: I *censor*ed up before hand and removed operator by accident thinking I could just set up a moderator rank to replace it. Is there anyway I can get the operator rank back. I've tried re-installing both ULib and ULX and it doesnt give me the operator rank back...
Thanks,
Alden
« Last Edit: November 03, 2016, 02:53:23 pm by JamminR »
Alden
« Reply #5 on: November 02, 2016, 06:47:01 pm »
Where can I find FAdmin?
    • Steam Page
« Reply #6 on: November 02, 2016, 08:31:35 pm »
Holding tab should bring it up by default. It's the default scoreboard in DarkRP
Alden
« Reply #7 on: November 02, 2016, 09:03:12 pm »
Im running a Nut Script WWII server, can I still find it via tab?
« Reply #8 on: November 03, 2016, 07:30:09 am »
They should still run on darkrp base, hold tab and there's like a server settings or something like that (not very familiar, sorry) in the bottom right, I think, there should be an Edit Groups or something option that you can see which permissions they have
Tbh I've only been a dev for a darkrp server once and we didn't even use FAdmin because I had no idea how to integrate it with ULX :P
Personally I'd recommend one or the other, you can disable FAdmin from the darkrpmodification addon, I believe.
« Reply #9 on: November 03, 2016, 02:57:22 pm »
It's starting to look like, with the experience level of discussion here, if you don't know how to use ulx addgroup to put a group back and inherit user, you should just see our FAQ section of the forum for resetting ULX to default/factory reset.
We also have a FAQ for how to disable FAdmin.
And iViscosity - no worries. Team Ulysses ourselves have trouble with integrating/letting ULX work with DarkRP.
We thought there was progress last year with a 'common' admin function library, but, well, yeah, that seemed to go belly up.
« Last Edit: November 03, 2016, 03:00:42 pm by JamminR »
