Author Topic: Ulx/Ulib svn latest version doesn't work!  (Read 5169 times)
Offline Freeza
« on: November 16, 2016, 12:33:27 pm »
ULib 3.71
ULX 2.61
Game mode(s) Darkrp
No lua errors!
So I had old ulx and thought "why not update?", so I did that, restarted and it doesn't work! Need help here, thanks!
Re: Ulx/Ulib svn latest version doesn't work!
« Reply #1 on: November 16, 2016, 01:57:44 pm »
How did you install it? Did you download it from the releases page?
« Reply #2 on: November 16, 2016, 06:28:55 pm »
Define 'not work'.
It works perfectly fine for thousands of other Gmod server administrators.
As for no errors, well, if it's not working, we're almost sure you're encountering an error, indeed, likely even lua.
Describe more clearly what is or isn't happening.
Offline Freeza
« Reply #3 on: November 17, 2016, 06:50:24 am »
Okay.
So, I downloaded the svn version from ulyssesmod.net and deleted my outdated ulx, put it in and restarting the server, no ulx commands work, it's like I haven't even put it in addons folder whilst I have.
« Last Edit: November 17, 2016, 06:52:33 am by Freeza »
« Reply #4 on: November 17, 2016, 07:14:41 am »
Okay.
Can you verify your folder structure is correct?
Your directory tree should be something like this:
addons/
  | - ulx/
       | - lua/
and so on. Basically, make sure that lua/ is directly below your ULX directory, which is directly below addons/.
Offline Freeza
« Reply #5 on: November 17, 2016, 07:20:13 am »
Well mine is:
  1. Branches, tags, trunk, svn.
Offline Freeza
« Reply #6 on: November 17, 2016, 09:18:56 am »
Nevermind guys!!
Fixed it!
Problem was that I dragged in all svn files, which created some problem (don't know what problem), I simply dragged out ulx 3.71 and ulib 2.61 folders and dragged it to addons haha!
