Author Topic: Got another problem... again...  (Read 4373 times)
Offline Freeza
« on: November 17, 2016, 09:27:32 am »
Hello again!
So I wanted to take some custom commands and implement it from my new updated ulx, but it comes a problem, when I've implemented it no errors come but it is uncategorized for some reason...
So I could need some help here thanks :)
Ulx version: 3.71w
Ulib version 2.61w
Gamemode: darkrp
No errors displayed as i did copy n paste :/
One more question: How do I remove my old custom commands from my new ulx? I implemented the custom commands at an outdated ulx...
« Last Edit: November 17, 2016, 09:29:29 am by Freeza »
Re: Got another problem... again...
« Reply #1 on: November 17, 2016, 09:32:55 am »
To remove old commands delete the add-on then remove your misc_registered file from data/ulib/
Not sure about your other problem though.
Offline Freeza
« Reply #2 on: November 17, 2016, 09:56:29 am »
Well, I did not do that way to implement addons.
I created a new lua file, implemented all the codes and before it worked... Maybe it doesn't work because I implemented the custom commands at an outdated ulx,ulib..
P.S: Are you sure nothing will happen with the default commands if I remove the misc file in data/ulib?
« Last Edit: November 17, 2016, 09:58:52 am by Freeza »
« Reply #3 on: November 17, 2016, 10:23:10 am »
The file will simply rebuild with every command you have. Did you put your commands in your default ulx addons folder?
« Last Edit: November 17, 2016, 12:57:43 pm by iViscosity »
Offline Freeza
« Reply #4 on: November 17, 2016, 10:38:31 am »
Yes, I did that..
« Reply #5 on: November 17, 2016, 01:00:44 pm »
Did you upgrade ulx recently? When you upgrade ulx it rewrites the ulx addon folder. It should always be "addons/yourcustomaddon/lua/ulx/modules/sh" for your custom commands. You can replace "sh" with "sv" or "cl", but you shouldn't put custom commands in the default ulx folder as it makes updating a pain in the ass.
