Author Topic: Fixing ULX MySQL Auth with FAdmin  (Read 3618 times)
Offline danhaynes9
« on: November 17, 2016, 11:40:24 am »
ULib v2.61d
ULX v3.71d
Lua errors shown in console, if any: none
<insert errors here>
So the problem is that I moved all my ulx data to a mysql database (with the ucl.lua that MrPresident made a while ago, /index.php/topic,8377.0.html and now when players join it loads ulx first so it sets the rank properly from the mysql but then it loads FAdmin and overwrites their usergroup. I would like to keep both as my admins use both. Thanks for the help fellas!
Re: Fixing ULX MySQL Auth with FAdmin
« Reply #1 on: November 17, 2016, 09:04:56 pm »
This isn't a ULib problem, nor a Team Ulysses release issue.
As you describe, ULib is loading perfectly when players join.
This is a Fadmin problem (it's overwriting your settings in UCL)
If you were skilled enough to figure out what you describe for MySQL and user conversion, perhaps figure out a way to prevent Fadmin from overwriting groups yet still allowing commands.
We've notified many people in the past asking this SAME issue regarding two admin mods and groups getting overwritten the same answer many times.
Disable Fadmin.
This may seem callous - perhaps in some ways it is.
We've tried to co-exist - even went so far as to use FPTje's 'universal admin library' which in theory was a good idea.
Then even it started conflicting with standards we tried following.
