Author Topic: Make echo visible for players, but not when superadmin use it.  (Read 4387 times)
Offline machond
« on: November 30, 2016, 02:53:28 pm »
Hey, I have a question. I made that players see the commands of other administrators (echo 2). However, I want to make the command superadministrator remain invisible.
I set echo to show echo and identify admin. But now i want make exception - if superadmin (or specify group) use command - then echo will be " (someone) slap Nickplayer."
How can i do this?
Thanks for help.
Re: Make echo visible for players, but not when superadmin use it.
« Reply #1 on: November 30, 2016, 03:03:44 pm »
ULX doesn't have this capability exactly as you want.
However, you could set mode to 1 and then grant groups you wanted to have see who did what while in echo mode 1 with "ulx seeanonymousechoes" access.
Those with that access will see all though, not just some admins but not others.
A bit more control than just using 2 however.
Good summary discussion -
See /index.php/topic,5998.30.html />Ignore the person who got mad at us for not asking proper questions.
Stickly's answer several below first post do a good job summarizing.
« Last Edit: November 30, 2016, 03:15:20 pm by JamminR »
Offline machond
« Reply #2 on: November 30, 2016, 04:33:36 pm »
Ok, i know that. But can i modify a little code in addon and change it to those i want?
I mean - is it possible to modify ulx to set it i want?
If yes, what i need to change?
« Reply #3 on: November 30, 2016, 07:21:22 pm »
This isn't the section to discuss such code, nor would it be easy, or recommended, to change.
You'd have to make lots of changes every time ULX updated.
