Author Topic: XLib Documentation  (Read 16194 times)
Offline captain1342
  • Quality is our standard
XLib Documentation
« on: December 26, 2016, 10:44:05 am »
Heyo,
I am working on a XGUI Module for my Lua Script MRSync ... but I can't find a Documentation for it so... do i Need to search for the stuff I Need in the Lua file or is theer a Documentation i am just to stupid to find?
thanks for reading,
~RD
Re: XLib Documentation
« Reply #1 on: December 26, 2016, 01:33:37 pm »
No documentation other than the lua files themselves - but at one time he actually thought he'd have time to do it.
Reference - /index.php/topic,9110.0.html#msg46561
Offline captain1342
XLib Hidepanel
« Reply #2 on: December 30, 2016, 09:31:52 am »
Hey is there a way to hide ^text Entrys fully? I Just make them non selectable when i set visible to false
« Last Edit: December 30, 2016, 09:39:47 am by captain1342 »
Offline roastchicken
  • I write code
« Reply #3 on: December 31, 2016, 04:19:21 am »
What do you mean by "hide fully?" Isn't making them unselectable and invisible hiding them fully?
Offline captain1342
« Reply #4 on: December 31, 2016, 06:45:32 am »
Strangely.. making them Unselectable and Unvisible doesent make them Unvisible .. but when i just make them Invisible it works
  • I write code
« Reply #5 on: January 01, 2017, 02:23:45 pm »
Can you give us a code snippet to show exactly what you're doing?
Offline captain1342
« Reply #6 on: January 04, 2017, 11:50:57 am »
http://pastebin.com/1NPCpcdD
Thats where I get Currently Errors
and here is the Error:
[ERROR] lua/vgui/dlistview.lua:107: attempt to index local 'Line' (a nil value)
  1. RemoveLine - lua/vgui/dlistview.lua:107
   2. DoClick - addons/msync/lua/ulx/xgui/settings/cl_msync_gui.lua:162
    3. unknown - lua/vgui/dlabel.lua:232
it means this MSync.Modules.enabledModulesList:AddLine( MSync.Modules.enabledModulesList:GetSelected()[1]:GetValue() )
but i dont see anything wrong with it
  • I write code
« Reply #7 on: January 04, 2017, 01:56:02 pm »
I don't think it's that line. The error references RemoveLine, but the line you're saying is causing the error doesn't remove a line; it adds one. My best guess is that it's the next line, but I can't be sure unless you give me the entire file so I can cross reference the line numbers. I'm on an airplane now, posting this via the in-plane WiFi (painfully slow in-plane WiFi, might I add. But I am on a plane, thousands of feet up in the air, so I'm not sure why I expected better), so I can't test what DListView:GetSelected returns. But my guess is that when it returns a table of the lines (according to the wiki), it's not returning a table of the line numbers. I'll do some spelunking in the code for DListView to see what exactly GetSelected returns and how to get the line number from a line (because it doesn't seem to be documented in the wiki) and get back to you.
edit 2: The magic of GitHub strikes again. If the version of DListView_Line on GitHub is to be trusted, then you should be able to do something like Line:GetID() and supply that as the argument to DListView:RemoveLine(). I should probably be a good citizen and document this on the wiki, but I'm lazy and not looking forward to waiting for the page to load on this slow WiFi. Maybe once I get home.
An additional, less important, fact is that DListView:GetSelected()[1] is identical to DListView:GetSelected() (according to the wiki, at least. It's proven to be less than accurate in the past, but usually pretty good).
edit: Looking back at the previous replies, I'm very much confused what this has to do with XLib or making things invisible.
« Last Edit: January 04, 2017, 02:03:20 pm by roastchicken »
Offline captain1342
« Reply #8 on: January 04, 2017, 03:56:41 pm »
GetSelected returns a Table cause it allows to give the full Selection back .. but strangely it stays Empty and says its nil but that cant be true .. i mean i see the entries.. also it is add line cause remove line is doing its job but re adding the line to the other table doesent work
  • I write code
« Reply #9 on: January 06, 2017, 10:05:20 am »
I'm not sure what your issue is. Are you still having errors?
Offline captain1342
« Reply #10 on: January 06, 2017, 06:49:44 pm »
Add line is Causing issues cause Remove line does its Job .. and now I dont know what to do.. i mean i need it for a Disabled and Enabled modules list .. if you know a better way to do that then please tell me
  • I write code
« Reply #11 on: January 09, 2017, 11:53:24 am »
Again, please provide me with any errors and the full files those errors point to. Without this crucial information any help I give is just guesswork. I'm still skeptical that your issue is with the Add line, but I can't weigh in further without the full file so I can look at the corresponding line numbers.
Offline captain1342
« Reply #12 on: January 22, 2017, 09:26:06 am »
Now a COMPLETE other thing .. i need to Overwrite the ULX ban and ULX banid commands to be able to write bans into a database but when i overwrite it with
  1. function ulx.banid( calling_ply, steamid, minutes, reason )
  2.                 steamid = steamid:upper()
  3.                 if not ULib.isValidSteamID( steamid ) then
  4.                         ULib.tsayError( calling_ply, "Invalid steamid." )
  5.                         return
  6.                 end
  7.
  8.                 local name
  9.                 local plys = player.GetAll()
  10.                 for i=1, #plys do
  11.                         if plys[ i ]:SteamID() == steamid then
  12.                                 name = plys[ i ]:Nick()
  13.                                 break
  14.                         end
  15.                 end
  16.
  17.                 MSync.AddBanID(steamid,reason,calling_ply,minutes)
  18.
  19.         end
  20.
  21.         function ulx.ban( calling_ply, target_ply, minutes, reason )
  22.                 if target_ply:IsBot() then
  23.                         ULib.tsayError( calling_ply, "Cannot ban a bot", true )
  24.                         return
  25.                 end
  26.
  27.
  28.                 MSync.AddBan(target_ply,reason,calling_ply,minutes)
  29.         end
Then it still bans Regular with the Local ban File
« Reply #13 on: January 22, 2017, 01:39:35 pm »
Or, you could just make your addon look through the ban table (ULib.bans) and add it that way. Look at this for information about how it works.
Offline captain1342
« Reply #14 on: January 22, 2017, 02:26:14 pm »
Then it would need to check the table every 5 minutes which would cause Lags due to the MySQL query which is repeating
btw my code works but it doesent load ... I need to manual load the file to get it working .. maybe ULX isn't loaded when the file loads
