Author Topic: Command help  (Read 5305 times)
Offline Dolph1n
Command help
« on: January 07, 2017, 05:21:38 pm »
So, I'm not the best at coding, but I know basics and I'm pretty good at using ctrl+c and ctrl+v, so go easy on me.
Anyways I'm trying to make a command  for TTT that will check if you are alive, and if you are will give you a Tsay, and if you're NOT alive it will force you to spectate a player(like ulx spectate does).
Here's what I have so far:
function ulx.spectate( calling_ply, target_ply )
if not calling_ply:IsValid() then
Msg( "You can't spectate from dedicated server console.\n" )
return
for k,v in pairs(calling_plys) do
if v:Alive() then
Msg( "You can't spectate while alive!" )
calling_ply:Kill()
calling_ply:SetForceSpec(true)
calling_ply:SetTeam(TEAM_SPEC)
calling_ply:ConCommand( "ttt_spectate" )
calling_ply:ConCommand( "ttt_spectator_mode 1" )
calling_ply:Spectate( OBS_MODE_IN_EYE )
calling_ply:SpectateEntity( target_ply )
ulx.fancyLogAdmin( calling_ply, true, "#A began spectating #T", target_ply )
When I use the command, nothing happens and I get this error:
[ERROR] addons/ulx/lua/ulx/modules/sh/util.lua:200: function arguments expected near ':'
  1. unknown - addons/ulx/lua/ulx/modules/sh/util.lua:0
EDIT: I think I got it, retrying.
Ok, so I no longer get the error but nothing happens, at least while alive.
EDIT 2: Nothing happens while dead either.
EDIT 3: It's no longer a recognized command by ULX. Fun.
EDIT 4: There's gonna be a lot of edits in this. Wow I'm bad at coding.
I moved some "end"s around and got it to be a command again, but now I get this error:
[ERROR] addons/ulx/lua/ulx/modules/sh/util.lua:196: bad argument #1 to 'pairs' (table expected, got nil)
  1. pairs - [C]:-1
   2. call - addons/ulx/lua/ulx/modules/sh/util.lua:196
    3. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
     4. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
      5. unknown - lua/includes/modules/concommand.lua:54
« Last Edit: January 07, 2017, 06:17:30 pm by Dolph1n »
Re: Command help
« Reply #1 on: January 07, 2017, 08:49:03 pm »
  1. function ulx.spectate( calling_ply, target_ply )
That is your function statement.
  1. for k,v in pairs(calling_plys) do
This is the line giving the error.
Nowhere in your code do you have a 'calling_plys' variable set. pairs requires a table as an argument, and because calling_plys is not defined anywhere (hint: nil) the function returns nil. The error thrown says exactly that, it expects a table but a nil statement was given.
I don't really understand why you're using a for k,v loop, because when someone calls a command, there's only going to be one person calling it, and one target. So really, you can remove the whole for loop, check if calling_ply:Alive() then he can't do it, else he can.
EDIT: Just realized your error pointed to the default ULX location. While you can do this, this is a bad idea because when ULX and ULib are updated, your command is going to be overwritten. Put it in something like
addons/<yourAddonName>/lua/ulx/modules/sh
EDIT2: Msg only echoes to the Dedicated Server console (the RCon). To get it to go to the player, you'll need to use Player:PrintMessage or ULib.tsay
« Last Edit: January 07, 2017, 08:55:46 pm by iViscosity »
Offline Dolph1n
Re: Command help
« Reply #2 on: January 08, 2017, 12:17:55 am »
What about something like this?
msg( "You can't spectate from dedicated server console.\n" )
return
for v in pairs(calling_ply) do
if v:Alive() then
calling_ply:PrintMessage( "You can't spectate while alive!" )
table.insert(affected_plys, v)
calling_ply:Kill()
Re: Command help
« Reply #3 on: January 08, 2017, 10:54:00 am »
That should work, however the 'msg' at the top as it is a nil value, it is case sensitive, Msg.
EDIT: Also, you can use  to highlight your lua.
« Last Edit: January 08, 2017, 10:56:20 am by iViscosity »
