Author Topic: Gmod automatic AOD god (and message)  (Read 6705 times)
Offline Shadowmist
« on: January 21, 2017, 12:52:51 pm »
Hello there, I was wondering if you guys have an idea on how to make it say "*player* has gone AOD!"
Here's my system for the godmode
if (SERVER) then
local adminondutyteams = { TEAM_ADMIN }
hook.Add("PlayerShouldTakeDamage", "godmodeAdminsss", function(ply)
if ( ply:IsPlayer() ) then
for i, v in ipairs(adminondutyteams) do
if ply:Team() == v then
return false
But does anyone have a clue how to make it so it says *playername* has gone aod!?
Would I have to make a PlayerSay hook that gets called when they go admin on duty? I am not sure how though.
Maybe
if Player:Team == TEAM_ADMIN then
AddChat( "v:Nick has gone AOD!" )
?????? Thank you.
Offline Shadowmist
Re: Gmod automatic AOD god (and message)
« Reply #1 on: January 21, 2017, 02:52:26 pm »
I need to test this ingame but I believe I've found it.
concommand.Add( "Shadowfunc",
function shadowfunction()
local ply = LocalPlayer()
if ply:Team() == "TEAM_ADMIN" then
ply:GodEnable
print "You're not admin! You can NOT have godmode! HAHAHAH"
Lmao wait I forgot to add the addchat thing.. the point in making this post xD
Offline BlueNova
« Reply #2 on: January 21, 2017, 08:29:30 pm »
This is just something I noticed.
But first thing when you have
It prints in console. If you want an error print it's more like
ULib.tsayError( calling_ply, "You're not admin, you cannot have godmode!" )
Furthermore,
When you try to get someone's nickname it needs to be v:Nick()
Just doing v:Nick won't work (at least I won't think it will)
As for
Maybe
?????? Thank you.
Perhaps adding the following instead
ulx.fancyLogAdmin( calling_ply, "#A has gone AOD!" )though DarkRP should have a default way to echo if someone changes class.
I haven't worked with DarkRP too much so this may not be 100% correct, but it's just stuff I noticed.
Edit: Ignore most of the above. I didn't see you were making hooks and the likes. What I wrote probably won't work but I'll leave it just in case it does.
« Last Edit: January 21, 2017, 09:16:56 pm by BlueNova »
Offline Shadowmist
« Reply #3 on: January 22, 2017, 03:45:18 am »
I have some sort of idea now.
I've scrapped all of that.
Here's how the chat thing works:
Serverside is
util.AddNetworkString( "sf_name" )
function aod()
ply:GodEnable
net.Start( "sf_name" )
net.WriteString( ply:Name )
net.Send( ply )
end )
clientside is
function HasGoneAod()
local name = net.ReadString()
chat.AddText( color( 0, 255, 255 ), name, "Has gone AOD! And have granted godmode upon themself.")
