Author Topic: ULib groups.txt Keeps Regenerating???  (Read 6738 times)
Offline BLEEP_BLOOP
« on: January 21, 2017, 01:49:53 pm »
I am having a problem with the groups.txt file in the ulib data folder. I have deleted the ulib and ulx folder in the data folder to wipe my groups to default settings. But, for some reason, the groups.txt keeps regenerating itself into how it was before the delete. I am using Ubuntu 16.04 Server. It does not regenerate when I delete the addon. I have deleted the ULX and ULib addon and corresponding data folders numerous times and cannot get it to reset. This is really weird and has never happened to me before. I have also tried rebooting. I am using the version that is downloaded from the ULX downloads page as a ZIP. Please help!
Re: ULib groups.txt Keeps Regenerating???
« Reply #1 on: January 21, 2017, 03:59:52 pm »
Do you happen to have any rank sync addons that could be syncing from some kind of database?
Are you also removing users.txt?
Offline BLEEP_BLOOP
« Reply #2 on: January 21, 2017, 08:49:45 pm »
I do not use any sort of database for ULX. I removed both multiple times and it still keeps regenerating. This is really weird.
« Reply #3 on: January 25, 2017, 09:46:27 am »
First question (probably obvious) is your server turned off when you remove the data files? Secondly, are you running FAdmin or other admin mod? Not 100% sure, but it could be possible that FAdmin is storing your added users and groups and ULX is regenerating them via CAMI.
Offline BLEEP_BLOOP
« Reply #4 on: January 25, 2017, 03:43:55 pm »
I already fixed this. Thank you @Stickly Man! for replying. It was FAdmin. It was storing groups, so I just wiped the FAdmin SQLite table.
« Reply #5 on: January 26, 2017, 06:25:30 pm »
Glad you got it fixed- good to know in case users have the same issues in the future. :)
