Author Topic: Making name not appear in Scoreboard spectators list  (Read 4830 times)
Offline sirrfuchs
« on: January 28, 2017, 02:00:19 pm »
I own a TDM Server, and well whenever I get on someone says anything, so I can't really keep an eye on things if everyone knows I'm on and starts behaving you know?
I'm basing this off several minecraft videos that I've watched and servers that have SV --- Super Vanish... The only thing that I want is my name to not appear in the menus / Scoreboard.
I can snippet part of my Current Scoreboard, at least the part that my dev friend says I need to edit.
local pos = Vector( red:GetPos() )
spec = vgui.Create( "DPanel" )
spec:SetPos( pos.x, pos.y + ScrH() - ( ScrH() / 8 ) + 3 )
spec:SetSize( 1170, 30 )
spec.Paint = function()
surface.SetDrawColor( 255, 255, 255, 222 )
surface.DrawRect( 0, 0, spec:GetSize() )
surface.SetTextColor( black )
surface.SetTextPos( 5, 5 )
surface.SetFont( "Exo 2 Content" )
local asd = {}
for k, v in next, team.GetPlayers( 0 ) do
table.insert( asd, v:Nick() )
surface.DrawText( "Spectators: " .. table.concat( asd, ", " ) )
function GM:ScoreboardShow()
CreateScoreboard()
function GM:ScoreboardHide()
if not ( red and blue ) then
return
red:SetVisible( false )
blue:SetVisible( false )
if spec then
spec:SetVisible( false )
My Dev is taking a break, so I'm taking back over the coding portions, I haven't touched it in a while and I would love some help!
Re: Making name not appear in Scoreboard spectators list
« Reply #1 on: January 28, 2017, 05:14:10 pm »
That loop in the spec.Paint function is where you'll need to check and make sure you're not inserted.
"v" is a player object, you could use something like an "if v:SteamID() ~= "your:_steamID:here" then table.insert( asd, v:Nick() )"
That would only not show you as a spectator though, from what I can tell from the code.
Be warned though, this will only hide you from TTT spectator menu. There are many other console and even Steam commands, and server info apps that will list who is on a server.
