Author Topic: votemap, but for gamemodes  (Read 6109 times)
Offline Splitzle
« on: February 12, 2017, 11:40:54 am »
Alright, I'm very very very new to LUA and what I've made so far is just from copying parts of other things in ULX. I want to make a votemenu that will change the gamemode.
With the code shown below, I can get a menu to pop up but nothing happens when I select an option. Can someone tell me how to fix this? I pretty much don't know what I'm doing so this may be very very wrong code.
local function rtgDone ( t, ply, sandbox, bhop, terrortown )
local results = t.results
local winner
local winnernum = 0
for id, numvotes in pairs( results ) do
if numvotes > winnernum then
winner = id
winnernum = numvotes
if #sandbox > 1 then
ULib.consoleCommand( "gamemode sandbox" )
if #bhop > 1 then
ULib.consoleCommand( "gamemode bhop" )
if #terrortown > 1 then
ULib.consoleCommand( "gamemode terrortown" )
function ulx.rtg( calling_ply )
local sandbox = "Sandbox"
local bhop = "Bhop"
local terrortown = "TTT"
if ulx.voteInProgress then
ULib.tsayError( calling_ply, "There is already a vote in progress. Please wait for the current one to end.", true )
return
local msg = "Switch gamemode to..."
ulx.doVote( msg, { sandbox, bhop, terrortown }, rtgDone )
local rtg = ulx.command( CATEGORY_NAME, "ulx rtg", ulx.rtg, "!rtg" )
rtg:defaultAccess( ULib.ACCESS_ADMIN )
rtg:help( "Starts a vote to switch the gamemode." )
Offline captain1342
  • Quality is our standard
Re: votemap, but for gamemodes
« Reply #1 on: February 12, 2017, 01:47:36 pm »
You forgot to reload the map .. if you change the gamemode you need to reload the map otherwise it isn't doing anything.
Offline Splitzle
« Reply #2 on: February 12, 2017, 02:34:47 pm »
I know, if I do "gamemode sandbox" in the server console it tells me that the gamemode was changed, then I reload the map. However with this it says nothing when an option is picked and reloading the map does nothing as well.
Offline captain1342
« Reply #3 on: February 12, 2017, 02:45:56 pm »
Did you tryed debuging= Like chek if the function rtgDone get called? then what Variables it gets then in the single parts print "Changing gamemode to:" that should give you feedback if it even gets called.
  1. local function rtgDone ( t, ply, sandbox, bhop, terrortown )
  2.         local results = t.results
  3.         local winner
  4.         local winnernum = 0
  5.         PrintTable(t)
  6.         print("Sandbox: "..#sandbox)
  7.         print("bhop: "..#bhop)
  8.         print("TTT: "..#terrortown)
  9.
  10.         for id, numvotes in pairs( results ) do
  11.                 if numvotes > winnernum then
  12.                         winner = id
  13.                         winnernum = numvotes
  14.                 end
  15.         end
  16.
  17.         if #sandbox > 1 then
  18.                 ULib.consoleCommand( "gamemode sandbox" )
  19.                 print("Changing gamemode to Sandbox")
  20.         end
  21.         if #bhop > 1 then
  22.                 ULib.consoleCommand( "gamemode bhop" )
  23.                 print("Changing gamemode to bhop")
  24.         end
  25.         if #terrortown > 1 then
  26.                 ULib.consoleCommand( "gamemode terrortown" )
  27.                 print("Changing gamemode to TTT")
  28.         end
  29. end
  30.
Try that and if it gives you feedback you should be fine then we can talk about other things.
Offline Splitzle
« Reply #4 on: February 12, 2017, 02:59:36 pm »
This was shown in the server console and it wasn't there before, so I guess it is being called.
spl voted for: Sandbox
args:
callback        =       function: 0x216d1a70
options:
                1       =       Sandbox
                2       =       Bhop
                3       =       TTT
results:
                1       =       1
title   =       Switch gamemode to...
voters  =       3
votes   =       1
L 02/12/2017 - 17:55:06: Lua Error: addons/ulx/lua/ulx/modules/sh/vote.lua:414: attempt to get length of local 'sandbox' (a nil value)
Nothing was said in the game chat.
« Last Edit: February 12, 2017, 03:02:31 pm by Splitzle »
Offline captain1342
« Reply #5 on: February 12, 2017, 03:36:12 pm »
Well the error message simply means that you try to get the lenght from a not existing table.
With #sandbox you get the lenght of an array but it looks like sandbox isn't given. That could be because Sandbox wasnt selected .. you should disable the 3 Variable prints at the beginning and try again ^^' btw you shouldnt edit ULX files .. you should create a new file for that. ULib is also aviable without editing the vote.lua
