ULX:## v3.72 - *(00/00/00)** [CHANGE] UTeam is now disabled for DarkRP gamemodes to prevent conflicts (Thanks, Bo98).* [CHANGE] "ulx bring" can now bring multiple targets (Thanks for the code, Timmy).* [CHANGE] Can no longer kick or ban (or use the vote variants) on the listen server host.* [FIX] More fixes for reading data from addon information (Thanks, Xylios).* [FIX] Server error when autorefreshing some XGUI server files (Thanks, Yupi2).* [FIX] Unexpected tags passed along in a log input (Thanks, mcNuggets1).* [FIX] Bad format spacing on UTF names for ulx who and and ulx debuginfo (Thanks for the code, toxsa).* [FIX] Potential persistence mechanism through ULX configs for rogue addons.ULib:## v2.62 - *(00/00/00)** [ADD] Enhancements from and to CAMI.* [ADD] Exec* functions can now execute only ULib-defined functions which are not marked "unsafe" (thanks, FPtje).* [ADD] Hooks for users being kicked, banned, unbanned; groups being created, removed, changed, renamed; user access being changed, or removed (thanks, Andre).* [FIX] Registers ULib-created CAMI groups on client side properly now (thanks, Roboderpy).
Log Message: ----------- Added Group Created Hook, replacing UCL Changed hook for it. Tested to be working.
