Author Topic: MapVote - Maplist Expansion  (Read 10964 times)
Offline Nolava
« on: March 21, 2017, 09:57:53 am »
ULib v2.62
ULX v3.72
Game mode(s) I am having this problem on: Terrortown
Lua errors shown in console, if any: -
Hello there!
I want to expand the List of the Mapvote to see more Maps. How can i do it?
Would be great if someone could help me :)
Re: MapVote - Maplist Expansion
« Reply #1 on: March 21, 2017, 12:07:28 pm »
You want to show more than 10 maps? We currently use Garry's voting framework (http://wiki.garrysmod.com/page/Player/AddPlayerOption), which only supports ten options. To change this would require quite a bit of extra code for the additional keys, different UI, or to implement vote paging.
Offline Nolava
« Reply #2 on: March 21, 2017, 05:19:14 pm »
Uhm i have "Fretta-like MapVote". I know it is possible to show more maps but i dont know how
« Reply #3 on: March 21, 2017, 05:38:33 pm »
ULX does not use Fretta
Offline Nolava
« Reply #4 on: March 22, 2017, 07:25:07 am »
So ULX got its own MapVote? But i got ULX an Fretta activated
« Reply #5 on: March 22, 2017, 11:24:57 am »
ULX uses a the built in voting system that garrysmod has. Having more than 10 vote options is not possible with this system unless we decide to rewrite it, which is unlikely at this moment due to the amount of work it would require.
« Reply #6 on: March 23, 2017, 11:19:32 am »
I think there's a bit of a misunderstanding here.
Nolava, Idon't think, is referring to ULX's built-in mapvote system. He's referring to the addon "Freeta-like MapVote," which has its own method for displaying a vote. If so, the configuration file (in /data/mapvote/config.txt) has a MapLimit key, which can be increased to suit your needs. The system will add a scrollbar if necessary.
