Author Topic: Console Command on server start  (Read 7550 times)
Offline EscudoDenali
« on: July 04, 2007, 02:17:50 pm »
I was wondering how I could make my server run a specified list of commands on start, if it is even possible.
"What I lack in skill, I make up for in stupidity." - EscudoDenali
Escudo's Non-Tolerance Server <--- FUN
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: Console Command on server start
« Reply #1 on: July 04, 2007, 03:05:34 pm »
server.cfg or server_cfg.txt
Offline Banyon
    • Kill 'a' Byte
« Reply #2 on: July 04, 2007, 03:58:14 pm »
These server_cfg.txt is just a text backup I do believe.  Its there for the purpose of showing you how to format one I think, although it appears to be formatted incorrectly.
Server.cfg is all the stuff for the server like defaultgamemode, cheats, rate settings, sv_lan, ect.
autoexec.cfg will also run commands and other scripts at start up.
example:
exec server.cfg
exec testscript.cfg
exec serverlocked.cfg
« Reply #3 on: July 04, 2007, 04:44:35 pm »
Don't forget the ULX configs! It has gamemode- and map-specific configs as well.
« Reply #4 on: July 04, 2007, 04:46:39 pm »
Meg posted while I was writing the following. It explains where what he said is.
See also your addons\ulx\lua\ulx\config folder.
Server.ini will let you configure many ulx commands.
There is also a addons\ulx\lua\ulx\<maps> or <config\maps> folder.
(Sorry, I'm out on travel right now and don't have an installation I can look at.)
In that is an example file explaining you can set various configuration depending on which map_name.ini is loaded.
« Reply #5 on: August 04, 2007, 11:06:31 pm »
Ok, so what I want to do is set it up so I don't have to change the server limits every time by making ULX menu save the settings or whatever, and I also want it to automatically run console commands like sbox_maxwire_rangers because A: ULX Menu doesn't support wire B: The wiremod control panel in utilities doesn't work with a dedicated server. So, can someone please walk through how to do both for me, like what files must I change and do I have to create any files, and where. Thanks in advance!
Offline ford460ho
« Reply #6 on: August 05, 2007, 12:47:50 am »
can any one give me a list of sbox commands
« Reply #7 on: August 05, 2007, 01:16:26 am »
