Author Topic: Forcing a picture on a screen?  (Read 4598 times)
Offline IncendiaryBlitz
« on: March 30, 2017, 06:17:42 pm »
Hi, I'm a bit new to Lua coding and want to make a ulx command that will show a picture on the screen of the target. Basically, I am making a jump scare command to play some pranks on the Owner of the server I develop. If someone could help me figure out the basis of making that command, it would be great!
Ps. My best guess is forcing a DFrame on the screen but at the same time, I don't know how to incorporate a pic into that.
Offline BlueNova
Re: Forcing a picture on a screen?
« Reply #1 on: March 30, 2017, 09:26:54 pm »
You could try something like this...
  1. function ulx.scare( calling_ply, target_plys )
  2.
  3.     for k, v in pairs ( target_plys ) do
  4.         v:SendLua([[gui.OpenURL("")]]) --URL to something goes here.
  5.     end
  6.
  7. end
  8.
  9. local scare = ulx.command( CATEGORY_NAME, "ulx scare", ulx.scare, "!scare", true )
  10. scare:addParam{ type=ULib.cmds.PlayersArg }
  11. scare:defaultAccess(ULib.ACCESS_ADMIN)
  12. scare:help("Have some fun why don't ya?")
  13.
I'm almost 100% positive there's a better way to do this but this is just something I thought of that you could try. Been a while since I wrote glua, or anything in ULX for that matter, but nevertheless this has the basic concept in mind.
« Reply #2 on: March 30, 2017, 10:28:49 pm »
Just use HUD elements. It's very easy to draw an image to a client using render textures.
http://wiki.garrysmod.com/page/render/DrawTextureToScreenRect
This would allow you to do that.
Here is some example clientside VGUI (This is obviously pseudo code)
If you are a developer, you should be able to read this and turn it into usable code no problem.
AddCSLuaFile()
myPicture = Material( "path/to/image.png" )
function MyJumpScare()
if not LocalPlayer().scared then return end
surface.SetDrawColor( 255, 255, 255, 255 )
surface.SetMaterial( myPicture )
surface.DrawTexturedRect(x, y, width, height )
you could then write your code/command to set the .scared = true to the local player using a net message or even
ply:SendLua("LocalPlayer().scared = true")
« Reply #3 on: March 31, 2017, 01:51:03 pm »
Awesome. Bothe of these will really help. Thanks!
