General
Developers Corner
Breach ULX command
Topic: Breach ULX command (Read 4618 times)
jcoolj13
Breach ULX command
April 04, 2017, 12:34:49 pm »
Hello, I need a breach ULX command where I can force a player to switch teams. Is that possible?
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: Breach ULX command
April 04, 2017, 07:05:15 pm »
/index.php/topic,8043.0.html#msg40822 />Some code exists in that thread in the code block at line 79.
You'd need to create your own console command for it, and adjust whatever teams your actual gamemodes use.
Also, I didn't search our releases forums. You may find a gamemode utility there someone has already written.
Even if not for your gamemode, it should be reasonably easy with base lua knowledge to switch.
With little lua knowledge, would be a good place to start learning.
General
Developers Corner
Breach ULX command
