Author Topic: Multiple function calls in a ulx command doesn't work.  (Read 4323 times)
Offline Rex744
« on: April 10, 2017, 12:20:03 pm »
The rest of the code above doesn't matter, just imagine a ulx custom command that has two if statements, if something then Easy() and if something then Medium(), the only thing that works is the first function which is Easy()
Example below:
function Easy()
RunConsoleCommand("Say","e")
 function Medium()
local example = ulx.command( "Voting", "ulx example"} )
example:help( "example" )
example:defaultAccess( ULib.ACCESS_ADMIN )
I need help getting passed this issue.
EDIT: I forgot to include elseif I just did a bunch of if statements.
« Last Edit: April 10, 2017, 02:46:18 pm by Rex744 »
Re: Multiple function calls in a ulx command doesn't work.
« Reply #1 on: April 10, 2017, 01:11:15 pm »
  1.        if winningOptionName == "Easy" then Mediums()
  2.             if winningOptionName == "Medium" then Mediums()
  3.             if winningOptionName == "Hard" then Hards()
  4.             if winningOptionName == "Insane" then Insanes
You never ended these if statements when they should've been. Use elseifs.
