Author Topic: Lua Coder Needed for a Vote Build/Fight Environment Script  (Read 15162 times)
Offline atomicspark
« on: July 05, 2007, 03:19:20 am »
I know you all are free and not busy with other projects :D, but if you could write me a quick script, that would be awesome. Basically I'm looking for a script that will change server variables. These variables would be sbox_noclip, sbox_playergod, and sbox_plpldamage (I think. It's all the ones in the !adminmenu except for enable NPCs).
Anyways let me know if you could help out. No pressure on time. I would just try to edit another script but I know how you guys can make code incredibly simple (ex. Megiddo's fly script). Let me know if "environment" isn't the best choice of word to use. I just want to enable some flexibility to my lil server. Thanks!
« Last Edit: July 09, 2007, 04:01:12 pm by atomicspark »
Offline atomicspark
Re: Lua Coder Needed for a Vote Build/Fight Environment Script
« Reply #1 on: July 09, 2007, 04:00:30 pm »
I have edited Luk0r's map reset vote to do what I wanted. Basically they just toggle sbox_playergod, sbox_noclip, and sbox_plpldamage. I wish I could condense this code into one file but my knowledge of Lua is very limited. If it was one file, only one vote request could run at a time. For instance, if it was currently a fighting environment (default) only the /votebuild command would work. I would also like it to advertise only the enabled vote command. This way it would be simple and conflicts would be kept to a minimum.
So if you guys can check it out and make suggestions, that would be great! Code below.
/lua/autorun/VoteBuild.lua
Version: 0.0
Author: [atomicspark] - www.atomicsparkonline.net
Original Code: Luk0r - luk0r@luk0r.net
For: Garry's Mod v10
vb = {}; vb.Settings = {}; vb.VotedFor = {}
// Configure these variables to suit your needs, the defaults will probably be fine though
vb.Settings.advertise  =  false        // Advertise the script?
vb.Settings.advdelay   =  300          // Delay in seconds between advertising.
vb.Settings.trigger    =  "/votebuild" // The chat trigger to begin a vote.
vb.Settings.votetrig   =  "/vote"      // Trigger to vote for the map reset (used when a vote is taking place)
vb.Settings.votetimer  =  30           // How long players have to vote.
vb.Settings.majority   =  60           // The majority of votes required for a reset in percent.
// Main code block
if CLIENT then return nil end
function vb.sendNotify( ply, text, sound, notifytype )
ply:SendLua("GAMEMODE:AddNotify(\"" .. text .. "\", " .. notifytype .. ", 5); surface.PlaySound( \"" .. sound .. "\" )")
function vb.checkForVoteTrigger( ply, txt )
if vb.votetakingplace == 0 then
if string.find( txt, vb.Settings.trigger ) then
vb.votetakingplace = 1
vb.votesfor = 1
table.insert( vb.VotedFor, ply:SteamID() )
local players = player.GetAll()
for i, plyr in ipairs( players ) do
vb.sendNotify( plyr, ply:Nick() .. " has requested a building environment!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
plyr:PrintMessage( HUD_PRINTTALK, "Type " .. vb.Settings.votetrig .. " to vote for the map reset.\n" )
plyr:PrintMessage( HUD_PRINTTALK, "Type nothing if you disagree.\n" )
vb.votereminder = vb.Settings.votetimer
vb.votereminderchunk = math.Round( vb.votereminder / 3 )
timer.Create( "vb.RemindPlayersOfVote", vb.votereminderchunk, 3, vb.voteTimerCheck )
timer.Create( "vb.EndOfVote", vb.Settings.votetimer, 1, vb.voteEnded )
return ""
vb.sendNotify( ply, "A building environment vote is already running!", "buttons/button2.wav", "NOTIFY_ERROR" )
return ""
if string.find( txt, vb.Settings.votetrig ) then
for i, vfornick in ipairs( vb.VotedFor ) do
if vfornick == ply:SteamID() then
vb.sendNotify( ply, "You have already voted!", "buttons/button2.wav", "NOTIFY_ERROR" )
return ""
vb.votesfor = vb.votesfor + 1
vb.sendNotify( ply, "You have voted for a building environment.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
plyr:PrintMessage( HUD_PRINTTALK, ply:Nick() .. " has voted for a building environment.\n" )
return ""
function vb.voteTimerCheck()
vb.votereminder = vb.votereminder - vb.votereminderchunk
if vb.votereminder > 0 then
vb.sendNotify( plyr, "Around " .. vb.votereminder .. " seconds remaining on the building environment vote!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
function vb.voteEnded()
playersonserver = 0
for i, v in ipairs( players ) do
playersonserver = playersonserver + 1
local majorityplayers = math.ceil( ( playersonserver * vb.Settings.majority ) / 100 )
if vb.votesfor >= majorityplayers then
vb.sendNotify( plyr, "The building environment vote has succeeded, the map will now reset.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
timer.Simple( 3, vb.enableBuild )
vb.sendNotify( plyr, "The building environment vote has failed.", "buttons/button2.wav", "NOTIFY_ERROR" )
vb.VotedFor = {}
vb.votetakingplace = 0
vb.votesfor = 0
function vb.enableBuild()
// game.ConsoleCommand( "changelevel " .. game.GetMap() .. "\n" )
game.ConsoleCommand( "sbox_playergod " .. "1" .. "\n" )
game.ConsoleCommand( "sbox_noclip " .. "1" .. "\n" )
game.ConsoleCommand( "sbox_plpldamage " .. "1" .. "\n" )
function vb.advertise()
vb.sendNotify( plyr, "To begin a building environment vote, type " .. vb.Settings.trigger .. " in chat.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
if vb.Settings.advertise == true then
timer.Create( "vb.Advertise", vb.Settings.advdelay, 0, vb.advertise )
vb.votetakingplace = 0  // Don't change these
vb.votesfor = 0
hook.Add( "PlayerSay", "vb.CheckForVoteTrigger", vb.checkForVoteTrigger )
/lua/autorun/VoteFight.lua
Version: 0.0
vf = {}; vf.Settings = {}; vf.VotedFor = {}
vf.Settings.advertise  =  false        // Advertise the script?
vf.Settings.advdelay   =  300          // Delay in seconds between advertising.
vf.Settings.trigger    =  "/votefight" // The chat trigger to begin a vote.
vf.Settings.votetrig   =  "/vote"      // Trigger to vote for the map reset (used when a vote is taking place)
vf.Settings.votetimer  =  30           // How long players have to vote.
vf.Settings.majority   =  60           // The majority of votes required for a reset in percent.
// Main code block
function vf.sendNotify( ply, text, sound, notifytype )
function vf.checkForVoteTrigger( ply, txt )
if vf.votetakingplace == 0 then
if string.find( txt, vf.Settings.trigger ) then
vf.votetakingplace = 1
vf.votesfor = 1
table.insert( vf.VotedFor, ply:SteamID() )
vf.sendNotify( plyr, ply:Nick() .. " has requested a fighting environment!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
plyr:PrintMessage( HUD_PRINTTALK, "Type " .. vf.Settings.votetrig .. " to vote for the map reset.\n" )
vf.votereminder = vf.Settings.votetimer
vf.votereminderchunk = math.Round( vf.votereminder / 3 )
timer.Create( "vf.RemindPlayersOfVote", vf.votereminderchunk, 3, vf.voteTimerCheck )
timer.Create( "vf.EndOfVote", vf.Settings.votetimer, 1, vf.voteEnded )
return ""
vf.sendNotify( ply, "A fighting environment vote is already running!", "buttons/button2.wav", "NOTIFY_ERROR" )
return ""
if string.find( txt, vf.Settings.votetrig ) then
for i, vfornick in ipairs( vf.VotedFor ) do
vf.sendNotify( ply, "You have already voted!", "buttons/button2.wav", "NOTIFY_ERROR" )
return ""
vf.votesfor = vf.votesfor + 1
vf.sendNotify( ply, "You have voted for a fighting environment.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
plyr:PrintMessage( HUD_PRINTTALK, ply:Nick() .. " has voted for a fighting environment.\n" )
return ""
function vf.voteTimerCheck()
vf.votereminder = vf.votereminder - vf.votereminderchunk
if vf.votereminder > 0 then
vf.sendNotify( plyr, "Around " .. vf.votereminder .. " seconds remaining on the fighting environment vote!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
function vf.voteEnded()
playersonserver = 0
local majorityplayers = math.ceil( ( playersonserver * vf.Settings.majority ) / 100 )
if vf.votesfor >= majorityplayers then
vf.sendNotify( plyr, "The fighting environment vote has succeeded, PvP damage enabled and noclip disabled.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
timer.Simple( 3, vf.enableFight )
vf.sendNotify( plyr, "The fighting environment vote has failed.", "buttons/button2.wav", "NOTIFY_ERROR" )
vf.VotedFor = {}
vf.votetakingplace = 0
vf.votesfor = 0
function vf.enableFight()
game.ConsoleCommand( "sbox_playergod " .. "0" .. "\n" )
game.ConsoleCommand( "sbox_noclip " .. "0" .. "\n" )
game.ConsoleCommand( "sbox_plpldamage " .. "0" .. "\n" )
function vf.advertise()
vf.sendNotify( plyr, "To begin a fighting environment vote, type " .. vf.Settings.trigger .. " in chat.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
if vf.Settings.advertise == true then
timer.Create( "vf.Advertise", vf.Settings.advdelay, 0, vf.advertise )
vf.votetakingplace = 0  // Don't change these
vf.votesfor = 0
hook.Add( "PlayerSay", "vf.CheckForVoteTrigger", vf.checkForVoteTrigger )
« Last Edit: July 09, 2007, 04:07:18 pm by atomicspark »
« Reply #2 on: July 09, 2007, 05:25:47 pm »
AtomicSpark, do you really want a vote? Or is that just what you ended up using?
Offline atomicspark
« Reply #3 on: July 09, 2007, 06:14:39 pm »
Voting is good so that users can vote on it? lol. I don't intend for this to be an admin only command. It's meant just for players.
« Reply #4 on: July 09, 2007, 07:23:02 pm »
I'm tinkering with combining the two. Gimme a day or two.
(I'm quickly running out of time today, sorry. Think I have most of it hacked.)
« Reply #5 on: July 09, 2007, 08:23:01 pm »
AtomicSpark.
 This is untested.
Tried to clean it up a bit. Renamed a command. Added a few variables.
Let me know what errors you get. I'll hopefully have more time tomorrow (Tuesday) evening to test/fix anything you find.
Name: Environment Vote (Fight/Build)
Version: 0.0
Code Note: Heavily modified by JamminR of Team Ulysses for [atomicspark]
vb.Settings.trigger.build    =  "/votebuild" // The chat trigger to begin a build vote.
vb.Settings.trigger.fight    =  "/votefight" // The chat trigger to begin a fight vote.
vb.Settings.currentmode = "Build"      // "Build" or "Fight" Mode that server runs at startup/default
// Main code block
           if string.find( txt, vb.Settings.trigger.build ) or string.find( txt, vb.Settings.trigger.fight ) then -- Check if either vote was requested
if string.find( txt, vb.Settings.trigger.build ) then -- Check if a build vote was requested
   if vb.Settings.currentmode = "Build" then -- Check if we're already IN build mode.
                      vb.sendNotify( ply, "Build mode is already engaged!", "buttons/button2.wav", "NOTIFY_ERROR" )
                      return ""
                       vb.voteinaction = "Build"
if string.find( txt, vb.Settings.trigger.fight ) then -- Check if a fight vote was requested
   if vb.Settings.currentmode = "Fight" then -- Check if we're already IN fight mode.
                      vb.sendNotify( ply, "Fight mode is already engaged!", "buttons/button2.wav", "NOTIFY_ERROR" )
                      return ""
                       vb.voteinaction = "Fight"
                vb.votesfor = 1
                    vb.sendNotify( plyr, ply:Nick() .. " has requested a "..vb.voteinaction.."ing environment!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
                return ""
if string.find( txt, vb.Settings.trigger.build ) or string.find( txt, vb.Settings.trigger.fight )then
vb.sendNotify( ply, "A "..vb.voteinaction.."ing environment vote is already running!", "buttons/button2.wav", "NOTIFY_ERROR" )
return ""
return ""
vb.sendNotify( ply, "You have voted for a "..vb.voteinaction.."ing environment.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
plyr:PrintMessage( HUD_PRINTTALK, ply:Nick() .. " has voted for a "..vb.voteinaction.."ing environment.\n" )
return ""
vb.sendNotify( plyr, "Around " .. vb.votereminder .. " seconds remaining on the "..vb.voteinaction.."ing environment vote!", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
playersonserver = 0
vb.sendNotify( plyr, "The "..vb.voteinaction.."ing environment vote has succeeded, the map will now reset.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
timer.Simple( 3, vb.enableEnvChange )
vb.sendNotify( plyr, "The "..vb.voteinaction.."ing environment vote has failed.", "buttons/button2.wav", "NOTIFY_ERROR" )
vb.VotedFor = {}
vb.votesfor = 0
vb.voteinaction = ""
function vb.enableEnvChange()
        vb.Settings.currentmode = vb.voteinaction
        if vb.voteinaction = "Build" then
vb.sendNotify( plyr, "To begin an environment vote, type " .. vb.Settings.trigger.build .. " or " .. vb.Settings.trigger.fight .. " in chat.", "ambient/water/drip" .. math.random(1, 4) .. ".wav", "NOTIFY_GENERIC" )
vb.votesfor = 0
/votebuild will start a build mode vote if it's not already in build mode or in progress.
/votefight will start a fight mode vote if it's not already in fight mode or in progress.
/vote does same, votes for whatever mode is being voted on.
Don't uncomment the map change code. I'm pretty sure changelevel forgets all the variables set, and it be 'dumb' to what mode is actually running.
Offline atomicspark
« Reply #6 on: July 09, 2007, 11:08:05 pm »
I saw that I forgot to change a line. The notification when you first start a vote still said something about a map reset. You seem to have caught that tho. I like your little code note in there. :) I haven't thought about releasing it on FP or anything, but credit is still good since it will be on here.
I'll check it out if I get around to it.
« Reply #7 on: July 10, 2007, 07:37:56 pm »
Any luck getting this running?
