General
Developers Corner
Giving Table Values
Topic: Giving Table Values (Read 4986 times)
BlueNova
Full Member
The most powerful force in the universe.
Giving Table Values
May 02, 2017, 12:44:03 pm »
So I just wanted to know if it's possible to give the values of a table, all of them that is.
If I remember correctly I don't think this will work.
weapons
"weapon_physgun"
"weapon_rpg"
ply
Give
weapons
Fairly confident that wouldn't work so is there a way to give all the values in a table or no? Thanks
MrPresident
Ulysses Team Member
Re: Giving Table Values
May 02, 2017, 12:56:58 pm »
You need to iterate through the table.
local
weapons
"weapon_physgun"
"weapon_rpg"
for
k
v
in
pairs
weapons
do
ply
Give
v
BlueNova
Full Member
Reply #2 on:
May 02, 2017, 01:04:01 pm »
Heh, now I'm ashamed for not seeing something that obvious. Thnx
iViscosity
Respected Community Member
Reply #3 on:
May 02, 2017, 03:24:52 pm »
Alternatively, you could iterate through it differently:
local
weapons
"weapon_physgun"
"weapon_rpg"
for
i
weapons
do
ply
Give
weapons
i
But to be honest, I use
pairs
more often, especially if the keys aren't numeric or in order.
BlueNova
Full Member
Reply #4 on:
May 02, 2017, 03:27:37 pm »
Thing is the first answer didn't work, forgot that ply:Give() wants a string value not a table value. I'll play with using numbers, etc until I get somewhere.
MrPresident
Ulysses Team Member
Reply #5 on:
May 02, 2017, 06:01:53 pm »
my method would have worked. It shouldn't return a table value.
v in the case of a k,v pairs loop would return the value inside the table.. which in the case of the example provided would be a string.
MrPresident
Ulysses Team Member
Reply #6 on:
May 02, 2017, 06:03:10 pm »
Example console output:
lua_run local testtab = { "test1", "test2" } for k, v in pairs( testtab ) do print(v) end
test1
test2
General
Developers Corner
Giving Table Values
