Author Topic: Can't Use Modeling Command In StarwarsRP?  (Read 5936 times)
Offline Narcotix
« on: May 07, 2017, 01:16:08 pm »
So I have recently started up a Garry's Mod server and for the first week or so I could use all ulx commands freely and then one day I loaded on and I couldn't use a large amount of commands due to them being moved to _Uncategorized including model, clearragdolls, removeragdolls. these 3 commands are very essential to swrp and i have tried everything to get this fixed. I have went through all of my addons and deleted any addons that have anything to do with ulx except for ulx and ulib (obviously). I cant seem to find where the coding for the actual commands are or i would've tried that. if you have any idea on why this is happening or this has happened to you let me know!
Re: Can't Use Modeling Command In StarwarsRP?
« Reply #1 on: May 07, 2017, 06:39:51 pm »
It's marked as uncategorized because you uninstalled the mod that had those commands. Those commands are not part of default ULX. To fix, reinstall the mod that contains them.
Offline Narcotix
« Reply #2 on: May 07, 2017, 07:36:22 pm »
In the past ive only ever had ulx installed and it worked
Offline Narcotix
« Reply #3 on: May 07, 2017, 07:39:09 pm »
not to mention isnt Model a default ulx permission
« Reply #4 on: May 07, 2017, 09:05:36 pm »
No.
ULX has none of these commands by default.
See our FAQ for what ULX has - What ulx commands should I see in "ulx help"?
model, clearragdolls, removeragdoll are not in default ULX.
You would have had to installed a custom mod, not made by us in Team Ulysses.
