Author Topic: Better jail  (Read 6437 times)
Sparky
Better jail
« on: July 06, 2007, 02:32:25 am »
I think ulx needs a better jail, many times on my server, they phys gun it and pieces fall off.
Or you could make it strip them when they are jailed.
Re: Better jail
« Reply #1 on: July 06, 2007, 03:12:26 am »
This is caused by one of your addons. The ulx jail is unbreakable as-is.
Offline Chironex
  • Formerly known as Kyzer
Re: Better jail
« Reply #2 on: July 06, 2007, 11:10:08 pm »
I modified the jail (making a larger one, stripping their weapons) but i would like to disallow them to kill themself, because they respawn with physgun (but still can't spawn things), and are almost stuck in a wall of the jail (:s) and so they can evade easily.
Is there a way to disallow the kill command while they're jailed ? Or do you have any others solutions to avoid escapes ?
Re: Better jail
« Reply #3 on: July 07, 2007, 01:19:02 am »
There's no method to disable the kill command. Instead, you could just strip their weapons again when they spawn by using the already existing spawn while jailed hook. (The one that moves them back to the jail.)
