Author Topic: TTT- Slow Mapchange  (Read 4963 times)
Offline Freakxdxx
TTT- Slow Mapchange
« on: June 04, 2017, 12:46:07 pm »
ULib v..newest
ULX v..newest
TTT
Error loading cfg/trusted_keys_base.txt (Not sure if it belongs to ULX)
Error loading cfg/pure_server_minimal.txt (Not Sure if it belongs to ULX)
Hello Ulx-Support,
I request that because I'd like to know if I lagg because multiple ULX addons
We just changed our V-Server to one with More RAM & CPU
The Mapchange still takes hours(30s) but on other servers its so fast
Thanks for the answer & sorry for the broken english
Greetings,
Porox
Re: TTT- Slow Mapchange
« Reply #1 on: June 04, 2017, 01:48:02 pm »
Not a ULX issue.
A slow map change could be caused by any number of things, but if you have a lot of addons I would bet that this is your issue.
How many addons are you running with your server?
Offline Freakxdxx
« Reply #2 on: June 04, 2017, 01:53:54 pm »
Actually a quite a lot, uncountable Addons
Our partner server has the same amount of Addons and their Server runs Smooth..
Just wondering what it could be since the console only writes some ULX things down.
Our new Vserver got like 24GB ram and 6 cores (Quite a good one, we want to build kind a network)
We now removed the .lua from Playermodels from the Addon section and that made it kinda faster
We copied our server from the old VPS and now its actually the same speed (Wondering how that could be possible)
Im thankful  for any hint.. Could it eventually be the Mapvote? (fretta)
greets
« Reply #3 on: June 04, 2017, 04:06:38 pm »
I use the fretta map-vote and map changes are smooth -- usually only takes a few seconds, but I also only have 57 small-ish workshop addons and a few legacy addons.
The amount of addons is not AS important as the size of each of those addons. Say you have 100 addons at 1 KB each, and another server with 100 addons at 1 MB each. The server with the smaller sized files will load faster because it can load through each addon faster.
The amount of addons on your server and the size of each of the addons is causing the server to take longer to mount all of the files.
Those could refer to a map installed incorrectly (as refered to in this thread on Facepunch) or something else. If nothing is wrong with those, it very well could just be the amount of large addons you have on the server.
