ulx_echo automatically change to 0. How to fix this?
Topic: ulx_echo automatically change to 0. How to fix this? (Read 4228 times)
M0NstR
June 09, 2017, 12:34:19 pm »
Hello, everyone. Please, help me. Why ulx_echo (from config.txt default: 1) automatically change to a value of 0? This happens every time the next round begins. Gamemode: TTT. I tried to reinstall, but it didn't help.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: ulx_echo automatically change to 0. How to fix this?
June 09, 2017, 04:54:12 pm »
Did you edit the file on the server, or your client?
Was the server shut down when you edited the file?
You can't edit ULX files directly while the server is running.
You can only set variables for the server when it's running using XGUI or server console.
M0NstR
Reply #2 on:
June 10, 2017, 06:29:06 am »
I edited this file on the server.
Server was alive, and shut down when I edited file. When I'm using XGUI round TTT began -> server automatically change on "Do not echo admin commnads".
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
June 14, 2017, 05:52:40 pm »
You might have "ulx_echo 0" in another configuration file on your server, worth checking if it's in any of the other files.
