Author Topic: I need help making a custom ulx command for Prophunt  (Read 5445 times)
Offline CARROT
« on: July 05, 2017, 02:13:38 am »
I need help making a custom ulx command for prophunt.
So the command is going to be an event command so I wanted it to be like you go into the ulx menu and click on the command then it brings up a down tab on the right side of the ulx menu with all the event you want like set server speed or server gravity then your click it then it will starts it up and then I was thinking of having a command that would set everything back to normal.
I kind of know what to do but I need help starting it.
