Author Topic: ULX Full Cloaking  (Read 5742 times)
Offline Darkblizzard
ULX Full Cloaking
« on: July 05, 2017, 02:37:41 pm »
Hello,
I've been noticing that the cloak ability is not working fully to where the physgun is able to be seen, chat above the head can be seen, and the name above the head can be seen. Is there a way to fix all of these issues? I'm running the latest version of ULX.
Thanks
Re: ULX Full Cloaking
« Reply #1 on: July 05, 2017, 07:14:07 pm »
I don't believe Gmod default Sandbox places any chat above the head.
You're likely using a conflicting addon, or a gamemode.
If that is the case, no, unfortunately, we can't fix it.
« Reply #2 on: July 05, 2017, 07:29:05 pm »
Ah, sorry. I meant the chat bubble is still seen above the head along with the two other things I've listed.
« Reply #3 on: July 06, 2017, 01:33:51 am »
Like JamminR said, gmod doesn't place a chat bubble above someone's head when they are typing. You have an addon or a gamemode that is adding this. We don't typically write compatibility like that for 3rd party systems.
« Reply #4 on: July 06, 2017, 01:35:32 am »
Also, in base garry's mod the name doesn't show above the head of the player. It only shows over your crosshair when you point at them. It sounds like you're wanting ULX cloak to modify your gamemode. You would need to code the gamemode to detect and obey ULX Cloak, not the other way around. Sorry.
« Reply #5 on: July 06, 2017, 08:10:04 am »
I suppose so, my main gamemode would be darkrp.
