Author Topic: ULX targeting  (Read 6365 times)
Offline hanleyjaa123
ULX targeting
« on: July 24, 2017, 10:27:19 am »
so i have ULX and i am trying to have it so some ranks can't pickup/target eachother order is here
trialmod
moderator
seniormod
gamemaster
admin
senioradmin
head-gm
head-admin
dev
owner
founder
extra:
Diamond
bronze
silver gold
custom
groups.txt https://pastebin.com/rJHHQd3K
i realy need help
Re: ULX targeting
« Reply #1 on: July 24, 2017, 10:48:24 am »
/index.php/topic,5346.0.html
Related: /index.php/topic,4314.0.html#msg16844
There's a search bar on the top right of the screen, you should use that before making a new topic, to see if it has already been asked before.
Re: ULX targeting
« Reply #2 on: July 24, 2017, 11:27:47 am »
i know but i don't understand it was wondering if someone else could explain it a bit better
Re: ULX targeting
« Reply #3 on: July 24, 2017, 11:35:39 am »
Ok. So say you have your group "trialmod". I'm assuming this is the lowest in your inheritance tree, so I'd guess your inherit_from would be "user". Assuming that "moderator" is your second group, the can_target for "trialmod" would be "!%moderator". What "!%moderator" means is "everything except" ( ! ) "the group 'moderator' and anything that inherits from it" ( %moderator ). I'm actually writing up a topic on this right now, so I can link it once I'm done if you still need help.
But your basics should be like this:
user
    inherits: none
    can_target: !%trialmod
trialmod
    inherits: trialmod
    can_target: !%moderator
moderator
    inherits: trialmod
    can_target: !%seniormod
and so on and so forth until you've reached the end of your chain. I recommend not having several 'branches' ( two groups inheriting from the same group ), it should be linear.
Re: ULX targeting
« Reply #4 on: July 24, 2017, 11:55:18 am »
user
    inherits: none
trialmod
    inherits: trialmod
moderator
    inherits: trialmod
This does help, link me after, but somtimes i get complaints that they can't pickup/ target a user
