Author Topic: Noclip help  (Read 4150 times)
Offline dofudofu
Noclip help
« on: September 01, 2017, 02:43:31 am »
ULib v2.63d (08/22/17)
ULX v3.73d (03/21/17)
DarkRP
Problem : When trying to use the "ulx noclip" command I get frozen in place and cannot move until I type it again, any help
Re: Noclip help
« Reply #1 on: September 01, 2017, 06:37:16 pm »
Most likely another mod is modifying the movement behavior while noclipped. You can check this by removing all other addons and seeing if the issue persists.
Offline Yananome
    • Joingy
Re: Noclip help
« Reply #2 on: September 07, 2017, 12:28:04 am »
I'm trying to figure out a noclip issue myself. Removed a few add ons and still have the same issue. I'll try to remove them all and see which one is causing the problem.
