Author Topic: [Solved]Can't use admin only weapons  (Read 15601 times)
Offline Happypug
« on: October 17, 2017, 03:28:22 am »
Whenever i try to spawn weapons with the golden shield nothing happens please help
« Last Edit: October 21, 2017, 04:53:19 am by Happypug »
Re: Can't use admin only weapons
« Reply #1 on: October 17, 2017, 01:56:15 pm »
Do NOT erase the questions our forum asks you when posting here.
Do you have ULib installed? If yes, what version?
Do you have ULX installed? If yes, what version?
What gamemode are you using?
When trying to use this "golden shield", are there any lua errors in game OR server console?
Does ULX see you as a admin or superadmin?
(Check this using "ulx who" in your server console while you are playing on your server.
Is the golden shield an addon?
Have you tried other admin commands?
Offline Happypug
« Reply #2 on: October 18, 2017, 12:25:16 am »
Do you have ULib installed? If yes, what version? V2.63
Do you have ULX installed? If yes, what version? V3.73w
What gamemode are you using? Sandbox
When trying to use this "golden shield", are there any lua errors in game OR server console? No
Does ULX see you as a admin or superadmin? yes it sees me as an owner
Is the golden shield an addon? Golden shield isn't an addon it's the thing that shows when an item is admin only
Have you tried other admin commands? yes they work fine
« Reply #3 on: October 18, 2017, 06:21:29 pm »
Owner is not a standard Gmod group. Though we've seen it mentioned in DarkRP, Sandbox and it's code have no idea what it is.
If you are indeed your server owner, you need to add yourself to "superadmin" using your server console.
Superadmin is the highest group gmod knows by default. It's root access. Top dog. Head cheese. ..., ... , ...
Reference our FAQs for how to add yourself at How do I make myself admin? (3 simple foolproof methods)
Offline Happypug
« Reply #4 on: October 19, 2017, 09:19:30 pm »
Solved,I deleted the ulx and ulib folders in garrysmod/data and the problem fixed itself
Offline Happypug
« Reply #5 on: October 21, 2017, 01:00:54 am »
You can mark it as solved admins.
