Author Topic: Console commands not recognized  (Read 6986 times)
Offline taekwondeal
« on: July 11, 2007, 04:55:17 pm »
When I type "ulx adminmenu" into the console I get the ULX admin menu, but when I try to make any changes, such as changing the prop limit, my server console returns the error "Unkown command "sbox_maxprops"'
What might be causing this?
Offline atomicspark
Re: Console commands not recognized
« Reply #1 on: July 11, 2007, 05:01:57 pm »
Are you superadmin? Only superadmins (or those with rcon access) can change settings in the admin menu.
Offline taekwondeal
« Reply #2 on: July 11, 2007, 05:04:36 pm »
I am indeed a super admin.
« Reply #3 on: July 11, 2007, 05:56:49 pm »
When you try using the command "sbox_maxprops 200" directly on your server console, does it give you an error or does it change the limit?
Offline taekwondeal
« Reply #4 on: July 11, 2007, 07:15:09 pm »
Typing it direclty into the console doesn't change the limit either.
« Reply #5 on: July 11, 2007, 07:32:46 pm »
Then it's not a problem with ULX but with your server. Are you getting errors on startup?
