Author Topic: Discord / Website ULX sync ranks?  (Read 19805 times)
Offline KewlerGames
« on: October 26, 2017, 05:30:27 pm »
So if it's possible I'm looking for something that if they get a rank it also gives it to them in discord and a mistfourm / Enjin website? I'm not sure if this is possible but I've never seen anyone even asking so here I am
Re: Discord / Website ULX sync ranks?
« Reply #1 on: October 26, 2017, 06:39:27 pm »
I'm not positive about syncing it to the website, but I know you can do it for Discord using their API.
You would need some way to identify the player on your Discord, though, as people may use different names. The way I do it on my test server is have a channel where people will post their Steam IDs (rather, a bot finds it for them using the Steam API), and periodically my script checks this channel's messages and looks for the ID (more information here). When it's able to find that, it compares that to the player's SteamID in-game, and then uses the Modify Guild Member call on them (which isn't completely supported at the moment because HTTP PATCH calls are currently unavailable on the main branch of gmod) to then edit their role.
Pseudo-code:
  1. function findPlayer( ply )
  2.         -- Use the HTTP() function (http://wiki.garrysmod.com/page/Global/HTTP) to launch a
  3.         -- GET request to your server
  4.         HTTP( {
  5.                 failed = function() end, -- do something on failure, maybe let the server know we failed?
  6.                 success = function( cody, body, headers ) -- This is where we look through the messages
  7.                         local data = body and util.JSONToTable( body ) -- Discord returns in JSON,
  8.        -- so we can access a table easily.
  9.                         -- Loop through the data, looking for the "content" tag (data[ i ].content)
  10.                                 -- If we find it, copy their ID (data[ i ].author.id)
  11.                                 -- If not, do something?
  12.                 end,
  13.                 method = "GET",         -- We're using an HTTP GET request, as specified by the
  14.                                                 -- Discord documentation
  15.                 url = "https://discordapp.com/api/channels/YOUR_CHANNEL_ID",    -- You can find the channel's ID by right-clicking the channel on the left and Copy ID (you may need to turn on Developer tools in User Settings)
  16.                 headers = {
  17.                         Authorization = "Bot YOUR_BOTS_CLIENT_ID" -- Discord mandates an authorization key in many HTTP requests, and if you're bot is authorized on your server, you can use it's ID. Note: You DO need to keep the leading "Bot" in there.
  18.                 }
  19.         } )
  20. end
  21.
  22. -- Now we actually set the person's role
  23. function setRole( ply )
  24.         -- Now we want to use the HTTP() function, but with a PATCH request.
  25.         -- Keep in mind, PATCH is NOT integrated in the main build of gmod, so it will not work for the moment.
  26.         HTTP( {
  27.                 failed = function() end,
  28.                 success = function() end, -- Since we're not trying to do anything on our side, we can just notify the server if we succeed, or just do nothing.
  29.                 method = "PATCH", -- Again, not implemented currently.
  30.                 url = "https://discordapp.com/api/guilds/YOUR_GUILD_ID/members/THE_USERS_ID", -- The Guild ID can be found by right-clicking the server's name in the upper left and click Copy ID, and the user's ID was found earlier. You could return the user's ID in findPlayer() and set this to "https://discordapp.com/api/guilds/YOUR_GUILD_ID/members/" .. findPlayer( ply ) as well.
  31.                 headers = {
  32.                         Authorization = "Bot BOT_CLIENT_ID", -- Again, this is required.
  33.                         roles = util.TableToJSON( {
  34.                                 -- Fill this with the IDs of the roles you want to give. This can be found by doing '\@role name' in Discord. You want to copy the numbers inside the brackets and paste them in here.
  35.                         }
  36.                 }
  37.         } )
  38. end
  39.
So, basically, it is POSSIBLE, just until the next update (says so) it is not, unless you use some third-party wrapper that allows PATCH requests.
« Last Edit: October 26, 2017, 06:58:41 pm by iViscosity »
Offline KewlerGames
« Reply #2 on: October 26, 2017, 09:39:15 pm »
I didn't include this but I'm new to the whole server developing stuff and I'm confused on where to put this and how to do it, I don't want to be spammy so I'll just include it in this post, is there a screen grab as of right now that's working? If not could someone help me in creating one with some starting code from a old one
Offline monkeymacman
« Reply #3 on: October 28, 2017, 09:10:26 pm »
Pseudo-code:
  4.    HTTP( {
  12.       end,
  16.       headers = {
  18.       }
  19.    } )
  20. end
  21.
  26.    HTTP( {
  31.       headers = {
  35.          }
  36.       }
  37.    } )
  38. end
  39.
I assume you must verify that the ID is actually them at some point, right? Do they need to have their discord account linked to steam?
« Reply #4 on: October 28, 2017, 10:28:58 pm »
I actually thought of this after I posted this but forgot to edit it. Basically I changed it so now the player uses a command (such as !register or !verify, I use !register) and then they type in their Discord username. It isn't 100% perfect because of duplicate nicknames, but when the script identifies them, it uses an HTTP DELETE request to delete that message, so it can only be requested once.
EDIT: Another idea, you could use the author's ID that you collect to file.Write that person into a file that tracks IDs, if that author's ID (which is unique to everyone) is already found, it would be ignored.
« Last Edit: October 28, 2017, 10:31:45 pm by iViscosity »
Offline BraveNM22
« Reply #5 on: December 10, 2017, 07:44:50 am »
So I have no idea for Discord and it looks like people already have an idea for that
However I use mistforums and I know it has a game integration addon that you can download from the admin panel. However I use things like "headmod" as my "Head of Mod" group name in ULX and mistforums will then use "headmod" and and that's my only problem with it :P
