Author Topic: ULX Command Restriction  (Read 5735 times)
Offline PureGamingHD
« on: November 07, 2017, 09:13:10 am »
Hello, I've been trying to figure out a way to restrict a ULX command to only be used by a certain player, instead of a certain group.
command:defaultAccess( ULib.ACCESS_SUPERADMIN ) is used for the group but I only want (SteamID) instead of a group. Is this possible?
Re: ULX Command Restriction
« Reply #1 on: November 07, 2017, 09:17:46 am »
Create a check in the command that returns if the ID doesn't match
« Reply #2 on: November 07, 2017, 12:36:10 pm »
Try using
ULib.ACCESS_NONE
Then assigning access to the user specifically through your console
ulx userallow <player> "ulx command"
That would give default access to nobody and then you could hand out the access to single users using the built in access. No need to add a check to the code.
