Author Topic: setting up ulx  (Read 6019 times)
Offline Jgweb2000
setting up ulx
« on: July 11, 2007, 10:04:27 pm »
so, finally rented a dedicated to replace my local dedicated i had running.
me being the newb i am, i had someone else completely install the local dedicated for me.
now that person is unavalible and i cant figgure out ulx
so, i uploaded the ulx files to the server (in the addons folder) then i restarted the server.
i read the readme, put my name/steam id in the settings/users.cfg (or whatever the extention was) and restarted
it has made my name green, but i was looking to use ulx for adminning, not garrys mod admin stuff, what console command do i type to give myself admin while im ingame or what do i do
i have irc, and was on earlier but the people online turned out to either be preoccupied or just plain old ignoring me.
thanks
Jgweb2000
Re: setting up ulx
« Reply #1 on: July 11, 2007, 10:33:55 pm »
Please read the sticky on this forum. Thanks!
Offline Jgweb2000
Re: setting up ulx
« Reply #2 on: July 11, 2007, 11:19:47 pm »
unknown command ulx
web
Re: setting up ulx
« Reply #3 on: July 11, 2007, 11:59:56 pm »
That means you did not install it correctly. Did you remember ULib? Errors on startup?
Offline Jgweb2000
Re: setting up ulx
« Reply #4 on: July 12, 2007, 06:30:59 am »
ulib comes with ulx correct?
and i cannot see the console (i guess i could use hlsw)
web
Offline SkuD
Re: setting up ulx
« Reply #5 on: July 12, 2007, 07:31:15 am »
If you put yourself in the users file in the settings/ folder and you show up green on the scoreboard, then it is a 99% chance you installed ulx/ulib wrong.  Ulx/ulib automatically adds you to the superadmin list if your name is in the users.cfg.
Re: setting up ulx
« Reply #6 on: July 12, 2007, 01:45:19 pm »
ULib does not come with ULX, it's a separate download (unless you use the installer).
