Author Topic: The server settings (from adminmenu) don't stay set when the server restarts?  (Read 4988 times)
Noodle
Hey.. I have ULX running on my server and so far its great.. but for some reason my admin settings don't stay set.  If I go to the adminmenu, change the options, then click apply, it changes them.. but if the server gets restarted, the settings return back to default.
Is there any way to fix this?  Is it a bug?  It's really driving me nuts.
Thanks
It's not a bug, it's how it's supposed to work. If you want settings to stay at a certain value, change it from a config file.
A bit more infor for those who care.
As stated, its not a bug. Server.cfg is the standard Valve SRCDS config file. ULX won't adjust it. We don't want to.
If you adjust settings frequently that you may not always want at server startup, but would like to have quickly available, make a new config file in <gmod>/cfg and then use the ulx exec (!exec) name.cfg command.
