Author Topic: What do you guys use to code?  (Read 17137 times)
« on: February 22, 2018, 08:21:49 pm »
Title.
I've been using Sublime 3 for the past 4 years, but I'm looking for something new. Some features I miss in Sublime are the auto-formatting (that is, on "ends" and the such, not just new lines inside "if" or "for" statements). Any suggestions? I'm a bit turned off to Notepad++, but if someone can convince me (MrP ;) ) I'll consider it.
Re: What do you guys use to code?
« Reply #1 on: February 22, 2018, 09:18:56 pm »
I used NP++ for years. I still like how simple it is, but they removed the plugin manager in the more recent builds and that prevented me from easily downloading the gLua highlighter. I switched to Sublime 3 and spent some time tweaking the UI to my liking and installed a glua highlighter and lexer. I quite like it.
I don't really know of any alternatives besides NP++ and Sublime 3.
Why are you looking to move away from Sublime?
« Reply #2 on: February 23, 2018, 04:06:57 am »
Just looking for something new, really.
« Reply #3 on: February 25, 2018, 12:09:49 pm »
I just switched from Sublime to Visual Studio Code. With a bit of tweaking it can be just as powerful as Sublime, it has a pretty awesome extension "Marketplace", and it's entirely free! aStonedPenguin has created a glua plugin that seems to work pretty well for autocompletes.
« Reply #4 on: February 25, 2018, 12:16:13 pm »
I do have Visual Studio from when I was messing around in C#... Maybe I'll check it out
« Reply #5 on: February 25, 2018, 12:23:04 pm »
Just to clarify, there is a difference between "Visual Studio" and "Visual Studio Code" :)
« Reply #6 on: February 25, 2018, 12:29:50 pm »
There is? Not positive which I have but I will check when I get home.
« Reply #7 on: February 27, 2018, 10:17:25 am »
I started with Notepad++ about 5-6 years ago, then switched to Atom a few years later.
Eventually got around to switching to Sublime Text (because Atom was extremely slow at certain points, primarily startup time), until I finally switched to VS Code a few months back (after hesitating for a bit).
While I love Sublime Text for it's blazingly fast startup time, VS Code isn't far behind and its extension marketplace seems to be a lot better than what I could get through Package Control in Sublime.
Nowadays I mainly use Sublime as a temporary notepad and editing/searching miscellaneous text/log files, and VS Code for actual development.
« Reply #8 on: March 02, 2018, 09:34:40 pm »
Thanks for the input. I've been using VS Code and very satisfied with it. I agree with you Decicus with Atom's slow bootup. I was happy when I found VS Code launches fairly quickly.
Offline BlueNova
« Reply #9 on: March 09, 2018, 10:39:09 am »
I use Notepad++ primarily. Though sometimes when I'm in the mood to switch things up I use Sublime for Visual Studio code. Have Dracula installed on Notepad++ and it's quite pretty.
« Reply #10 on: April 05, 2018, 04:33:36 pm »
At home I use Atom (never noticed any start-up time issues on a Mac); at work, I use Vim... simply because getting software approved at work is a major pain in the redacted. After being forced to use it for a while, I've actually come to enjoy it.
« Reply #11 on: April 05, 2018, 06:41:18 pm »
I work in a Windows shop, and, NP++ is approved.
The actual 'hardcore' dev group has access to/uses more, but for my various quick script and web work, NP++ does extremely well.
I use it at home too.
