Author Topic: Reset XGUI Theme  (Read 3973 times)
Offline Gabriel4321
Reset XGUI Theme
« on: March 29, 2018, 03:51:38 pm »
ULib v2.63d (02/16/18)
ULX v3.73d (02/11/18)
DarkRP
Very simply, one of my staff members was being silly and decided to mess with XGUI visual settings (colors, animations, etc.) for himself.
Two questions: 1. Is there a way to disable custom XGUI settings for clients, and 2. how can I reset my staff member's XGUI (it's completely blank and non-functional)?
Thanks! :)
Re: Reset XGUI Theme
« Reply #1 on: March 30, 2018, 09:53:24 am »
1. Unfortunately, there is no way to disable the client-side configuration settings.
2. The easiest way to fix his issue is for him to modify his data/ulx/xgui_settings.txt file- either delete it entirely or find the "skin" line and replace the value with "Default".
You might be able to fix it while he's on the server by having him run these console commands (or by sending them from your server to his client):
  1. xgui.settings.skin = "Default"
  2. xgui.base:SetSkin( xgui.settings.skin )
  3. xgui.saveClientSettings()
Offline Gabriel4321
« Reply #2 on: March 30, 2018, 09:09:21 pm »
All set, thanks! :)
