cmd:setOpposite() help
Topic: cmd:setOpposite() help (Read 3842 times)
Vaporouscreeper
April 01, 2018, 08:13:40 pm »
How do i use cmd:setOpposite()
i can't find in the ulib docs
I'm a Moderator on a server called TheBox. and i'm mostly active on it
iViscosity
Respected Community Member
Re: cmd:setOpposite() help
April 01, 2018, 08:25:48 pm »
http://ulyssesmod.net/docs/files/lua/ulib/shared/commands-lua.html#cmds.TranslateCommand.cmds.TranslateCommand:setOpposite
Basically it's cmd:setOpposite( "console_command", {list, of, args, to, specify}, "chat_command", hide_command_in_chat?, force_space_after_command? )
The list of args basically forces the function to use those args instead. For example, if you had args ( calling_ply, target_ply, should ) and the setOpposite should make that "should" argument false, you'd have { _, _, false }
