Author Topic: Best Anti-Cheat?  (Read 10664 times)
Offline PAL-18
Best Anti-Cheat?
« on: April 14, 2018, 12:56:12 am »
I'm getting back into hosting Gmod servers and i did a bit of research and Cake seems to be the best anti-cheat script available.  Is this the case or is there something better out there.  Is there anything that can block files being uploaded/downloaded?
« Last Edit: April 14, 2018, 12:59:45 am by PAL-18 »
Re: Best Anti-Cheat?
« Reply #1 on: April 14, 2018, 11:17:47 am »
I've used CAKE and it worked against the injection hacks that I tested against it.
As for uploading or downloading.. that's a bit trickier, because these things are only possible via exploits in the source engine. The anti-cheat would have to be coded to specifically target and block these.
Offline PAL-18
« Reply #2 on: April 14, 2018, 01:08:31 pm »
Cool, thanks for the info  ;)
Offline Tw2Stefan
« Reply #3 on: April 19, 2018, 04:59:59 pm »
I'm using both Cake and SIMPLac atm. I don't know how I feel about the latter as I'm still testing it, but the footprint on the server(s) is minimal, so it's at least worth a shot.
