Author Topic: Custom Jail  (Read 7230 times)
Offline Charlie Irwin
Custom Jail
« on: April 17, 2018, 12:48:59 pm »
Hey ,
I am wondering how I could make a command so when I jail someone it brings them to a certain area. I know !jailtp but that is not what I am talking about.
I want it so I can have a jail system where it automatically teleports them to the admin room on the bottom of my map because in rp_downtown_altered you get an admin room but I want that to be the place users go to when I jail them
Picture: https://steamcommunity.com/sharedfiles/filedetails/?id=1363982997
Re: Custom Jail
« Reply #1 on: April 17, 2018, 02:44:15 pm »
Take a look at jailtp.
Then rather than teleporting them to where you are, teleport them to a set coordinate.
I'd make this into a new command though since we don't recommend overwriting base code.
Re: Custom Jail
« Reply #2 on: April 18, 2018, 06:20:48 am »
Thanks,
I am not the best with LUA so where do I start with making a command?
Re: Custom Jail
« Reply #3 on: April 18, 2018, 05:53:02 pm »
We've pretty much spoon fed the answer.
JailTP code can be seen here.
Your challenges;
- Learning how to find out the co-ordinates of the place you want the person to go and plugging them into your own jailadmin command.
- Changing the function name, help and command name text.
- If the room isn't big enough for it's own jail, figuring out how to edit the example code to not A) Check space clearance for the walls - B) Not put up walls
- Learning how to create your own modules files, so it won't be stored with ours (hint, on server, this should work) - gmod/addons/My_ULX/lua/ulx/modules/sh/myULXcode.lua
- There will be more as you go, but those are the main ones to start wtih.
« Last Edit: April 18, 2018, 05:54:37 pm by JamminR »
