Author Topic: dedicared server admin help  (Read 14982 times)
pat
« on: February 10, 2006, 11:03:45 pm »
ok i got my ip steam id thing addUser STEAM_0:0:563225 right i go to ulx_users it says
-- Add users here, in the following format:
addUser( <STEAM_0:0:563225>, <bcdefghijklmnopqrstuz> )
-- Example:
-- addUser( "STEAM_0:1:1234567", "abcdefghijklmnopqrstuz" )
-- DO NOT INCLUDE THE '--' BEFORE addUser(), '--' DENOTES A COMMENT
-- Access flags:
-- a - immunity (can't be kicked/baned/slayed/slaped and affected by other commmands)
-- b - reservation (can join on reserved slots)
-- c - ulx_kick command
-- d - ulx_ban and ulx_unban commands
-- e - ulx_slay and ulx_slap commands
-- f - ulx_map command
-- g - ulx_cvar command (not all cvars will be available)
-- h - ulx_cfg command
-- i - ulx_chat and other chat commands
-- j - ulx_vote and other vote commands
-- k - access to sv_password cvar (by ulx_cvar command)
-- l - access to ulx_rcon command and rcon_password cvar (by ulx_cvar command)
-- m - spawned props will be "protected", only other users with this access will be able to delete them ( ALSO UNAFFECTED BY PROP ANTI SPAM )
-- n - ulx_ent command - CAUTION, PLAYERS MAY BE ABLE TO CRASH THE SERVER WITH THIS ACCESS
-- o - custom level A
-- p - custom level B
-- q - custom level C
-- r - custom level D
-- s - custom level E
-- t - custom level F
-- u - custom level G
-- z - custom level H
-- This is the access of the listen server admin
LISTEN_ADMIN_ACCESS      =   "bcdefghijklmnopqrstuz"
Is that finished is that like everything i have to do to become admin  on my dedicated server?? or do i need to type it in like console or client side :S the ulx_users is like got my user id and permission
what else do i need to do? when i join i type ulx_who says user id etc then end of list
how i fix? im trying beta now repley soon plz.
Re: dedicared server admin help
« Reply #1 on: February 10, 2006, 11:27:50 pm »
Use the new version
pat
« Reply #2 on: February 10, 2006, 11:49:32 pm »
1.1 the beta?
pat
« Reply #3 on: February 10, 2006, 11:54:16 pm »
 ??? ??? ??? ???the beta doesnt work for me i need the ulx_init to make it work then it dont work so im sticking with 1.0 but can some one show me what there ulx_users thing looks like?
plz so i can mimic it that way i no i am doing it write plz ok thanks admin who helped before but i still need more info ::)
« Reply #4 on: February 11, 2006, 12:17:43 am »
If you don't bother to take the time to use complete sentences, words, and at least attempt to use correct grammer, I do not feel compelled to try to decipher your message.
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #5 on: February 11, 2006, 01:01:15 am »
Type Status in console and get your steamid, then add this to the bottom of ulx_users
addUser( "YOURID", "abcdefghijklmnopqrstuz" )
pat
« Reply #6 on: February 11, 2006, 01:06:22 am »
thank you very much :)
pat
« Reply #7 on: February 11, 2006, 02:39:39 am »
well thanks anyway but didnt work this is what my ulx_users file looks like
-- addUser( STEAM_0:0:563225, bcdefghijklmnopqrstuz )
-- Example:
addUser( "STEAM_0:0:563225", "abcdefghijklmnopqrstuz" )
thats my users doc when i join type ulx_who
nobody name comes up if i type ulx_help only have 4 commands so i need some help
what else should i try? is there a plugin or somthing i can use to make it work please help me  ;D
    • BlueFire
« Reply #8 on: February 11, 2006, 10:37:09 am »
make sure you have that exact steamid there when you type status.
If its the exact ID you entered, im not sure. I dunno why so many people have problems with it.
pat
« Reply #9 on: February 11, 2006, 03:02:44 pm »
well look at what i wrote i put my users file in my steam id is in the example and the line at the bottom. do u think u could make a user doc for me? ill giv u steam id and stuff i need all access. if u cab thanks  :)
pat
« Reply #10 on: March 03, 2006, 04:42:27 pm »
any idears yet lol been a couple of months
    • BlueFire
« Reply #11 on: March 03, 2006, 08:50:42 pm »
Check the releases section for my ULX builder.
Offline Griff
« Reply #12 on: March 04, 2006, 11:36:10 am »
if were talking about 1.11 then...
i am having the same/similar prob so atm im gona stick with 1.0.
when i run the server, i notice it does NOT exec server.ini or users.ini
now considering the user permisions and server settings are in those files, it wont work. now i am guessing that the init folder will only exec lua's and not ini's considering when i tried adding that line it didnt work. so atm im a lil stuck. also i notice in the readme it talks about editing "ulx/users.lua" when there is no users.lua only users.ini in "ulx/configs/users.ini" im not sure but may you have overlooked this? or does some file relate to this folder.... but anyway, please help me.
« Reply #13 on: March 04, 2006, 12:14:52 pm »
Delete all previous ULX files and install ULX v1.11
Offline Griff
« Reply #14 on: March 05, 2006, 09:33:33 am »
all ulx files were moved to a seperate location incase of a problem(like this) and 1.11 didnt work..
im going to make a new gmod server folder and run from there, c if that works
