Author Topic: 2 Questions: Immunity and MOTD  (Read 6237 times)
Offline Mandude
« on: July 17, 2007, 08:27:51 am »
Hello, everyone.
I read through the forums about the physgun problems people seem to be having. I, too, have the problem where the physgun moves everyone, including admins. If I wanted to make admins and superadmins immune to physguns, what would be the command for that?
Secondly, my MOTD doesn't show up on anyone's screen when they join. My folder structure for the MOTD looks like this: garrysmod > addons > ulx > motd.txt. That IS where the MOTD is loaded from, right? When I type "!showMotd", the window comes up, but it's blank. I did type "showMotd" in the console before anyone joined, and that still didn't work. Do I have to type "showMotd" every time I start the server, or just once?
Sorry for all my questions - I spent about an hour trying to get these two things to work correctly and I read through the forums, but I couldn't quite seem to find a good answer. Thanks for at least reading this...I hope someone can help!
Re: 2 Questions: Immunity and MOTD
« Reply #1 on: July 17, 2007, 10:30:10 am »
Make them immune if you don't want them to be moved by the physgun. It's "!motd" to show the motd.
Offline Mandude
« Reply #2 on: July 17, 2007, 12:11:35 pm »
Right, but what is the command to make them immune to the physgun? Also, is there a reason why the MOTD is blank / doesn't show at startup?
« Reply #3 on: July 17, 2007, 12:52:24 pm »
You should really put motd.txt in the garrysmod root, and you make them immune by specifying it in adduser or adding them to the group manually.
Offline Chironex
  • Formerly known as Kyzer
« Reply #4 on: July 19, 2007, 02:56:47 am »
We had the same problem there is a few days, reinstalling ulx/ulib fixed it, the strange thing is that happen suddently :/
Megiddo what you mean in the garrysmod root, directly in garrysmod/garrysmod ? If this solve this problem then thanks i will try next time it's :D
