Author Topic: Server crash on map change  (Read 5791 times)
Offline Demo
« on: June 22, 2018, 07:33:53 am »
So, I was learning for exams and my team from TTT and RP spammed me with "The server crashes on map change" and its true.
This problem came out of nowhere. I have not changed a single thing. Then I removed every addon one by one and found out that ulx /ulib is causing this error:
Ammo crate detonation con var created
Segmentation fault (core dumped)
Add "-debug" to the ./srcds_run command line to generate a debug.log to help with solving this problem
Fr 22. Jun 16:29:11 CEST 2018: Server restart in 10 seconds
No map works except the start map. Not ttt_ map or rp_ map. Any idea? It worked perfectly some days ago...
Offline Demo
Re: Server crash on map change
« Reply #1 on: June 22, 2018, 01:04:54 pm »
This effected all my servers at the same time: 4 TTT servers, 1 DarkRP, 2 Testservers and 1 MilitaryRP server. No map can be changed and it's only because of ulx / ulib.
I'm wondering I am the only person getting this issue
Edit: Found out, ulib is causing this issue. But still searching a way to fix
« Last Edit: June 22, 2018, 01:35:58 pm by Demo »
