Author Topic: Command not showing up  (Read 5763 times)
Offline epictroller629
« on: October 14, 2018, 11:14:26 am »
I need help with these commands i cant see any of them in the XGui please help
DarkRP
local CATERGORY_NAME = "Respawn"
function ulx.respawn( calling_ply, target_ply )
    if not target_ply:Alive() then
    target_ply:Spawn()
ulx.fancyLogAdmin( calling_ply, true, "#A Respawned #T", target_ply )
local respawn = ulx.command( CATERGORY_NAME, "ulx respawn", ulx.respawn, "!respawn", true )
respawn:addParam{ type=ULib.cmds.PlayerArg }
respawn:defaultAccess( ULib.ACCESS_ADMIN )
respawn:help( "Respawns a player/target cmd made by Drew" )
function ulx.srespawn( calling_ply, target_ply )
    target_ply:Spawn()
ulx.fancyLogAdmin( calling_ply, true, "", target_ply )
local respawn = ulx.command( CATERGORY_NAME, "ulx srespawn", ulx.srespawn, "!srespawn", true )
respawn:help( "Silenty respawns a player/target cmd made by Drew" )
Re: Command not showing up
« Reply #1 on: October 14, 2018, 11:18:56 am »
I'm pretty sure it's because both of your commands use the same variable ("respawn") when defining the command.
« Reply #2 on: October 14, 2018, 11:20:12 am »
Well When I Has Only one command it still didnt work why?
« Reply #3 on: October 14, 2018, 11:22:21 am »
If you tried removing one after you had them both in, they'd still be defined in data/ulib/misc_registered.txt
« Reply #4 on: October 14, 2018, 11:24:58 am »
I'm Saying I Added srespawn After a test with just respawn
« Reply #5 on: October 14, 2018, 11:25:32 am »
And, if removing/deleting the misc_registered.txt doesn't help, we really can't read minds by looking at code.
At first glance for the time most of us have to take, the command should work, IF it's registered on both client and server.
If there are errors, look for them at server startup in server console, and in both server and game console when trying to run the command.
« Reply #6 on: October 14, 2018, 11:36:50 am »
I Have Fixed My Problem Thx For The Help  ;) :)
