Author Topic: People can't see what admin is running commands (Ban, Bring, etc)  (Read 6663 times)
Offline Monikas_Comin
I'm looking to change this. Is there a way to do so? I've looked for a while and found nothing.
Simplified:
I wanna change (Someone) brought You
to Ruby brought You
or etc.
Offline Timmy
  • Code monkey
Re: People can't see what admin is running commands (Ban, Bring, etc)
« Reply #1 on: December 17, 2018, 12:53:13 am »
Method 1: XGUI
Open XGUI > Click "Settings" tab > Click "Server" tab > Click "ULX Command/Event Echoes" > Select "Echo commands and identify admin" in the first drop-down list.
Method 2: Server console
Use the "ulx logEcho" console variable to control how ULX echoes commands.
There's 3 different modes:
0 - OFF No output to any players when an admin command is used
1 - ANONYMOUS Output to players without access to see who used the command (admins by default) similar to "(Someone) slapped Bob with 0 damage"
2 - FULL Output to players similar to "Foo slapped Bob with 0 damage"
In this case you'd set it to 2. So you would run:
ulx logEcho 2
« Reply #2 on: December 17, 2018, 02:40:07 pm »
Method 1: XGUI
ulx logEcho 2
This worked great for me! Thank you so much!
