Author Topic: Double server join messages showing in chat  (Read 4770 times)
Offline allofmywutsteam
  • MNWO Owner
    • MNWO Discord
« on: December 20, 2018, 03:15:56 pm »
ULib v..263
ULX v..373
Game mode(s) I am having this problem on: TTT
I installed Advanced Join and Leave (Supporting Sounds, Messages, GeoIP, Multi Coloring!, but I want to remove this default (green) loading text. I'm not sure where in the settings (addon or server side) that it needs to be removed.
The text shows when a user CONNECTS to the server (seen in console) rather than joins the server (as intended by the addon).
Re: Double server join messages showing in chat
« Reply #1 on: December 20, 2018, 04:22:42 pm »
You already asked in the proper release thread.
Please do not double post.
Additionally, This forum section is intended for Team Ulysses project help/discussion only.
That release was by a community member.
If the original author or anyone stopping by that release knows the answer, perhaps they will help.
EDIT - The original release has example showing - it's in the template config file.
Use hex color codes. Or presume set leave/join to "".
Original topic - /index.php/topic,7367.15.html
Github file (but you'd edit locally) - https://github.com/myudev/gmod_addons/blob/advjoinleave/advjoinleave/lua/autorun/server/ss_advjl_config.lua
« Last Edit: December 20, 2018, 04:33:30 pm by JamminR »
