Author Topic: Playsound Issue!! Please check it out!  (Read 5404 times)
Mutank
« on: July 21, 2007, 08:17:08 am »
I added the stuff to make it a foreced download and it still isn't downloading! I also have the latest version...
I heard people talking about sv_downloadurl. and wtf is that and how do i use it? I'm running a dedicated gmod 10 server
Offline atomicspark
Re: Playsound Issue!! Please check it out!
« Reply #1 on: July 21, 2007, 11:31:57 am »
Make sure your syntax is exactly the same as below.
/addons/ulx/lua/ulx/configs/server.ini
ulx addForcedDownload "sound/file.wav"
Sv_downloadurl is a way to reduce bandwidth usage (lessening lag) when someone joins a server. What it does is make them download content (maps, sounds, etc.) from a web server. This is assuming you aren't hosting the dedicated server and web server on the same connection. Read more about it below and how to set it up.
http://forums.srcds.com/viewtopic/1077
« Last Edit: July 21, 2007, 11:54:35 am by atomicspark »
« Reply #2 on: July 21, 2007, 11:38:33 am »
How do I use forceddownload?
Insert the files you want people to download into a ULX config file (server.ini, per-map configs, per-gamemode configs).
The format for the command is: ulx addForcedDownload "<file/folder>" [<recursive]
You can add a folder to add all files inside that folder. If recursive is 1 it will also add all files from any sub-folders. (ULX v3.20+ only!)
Linux folder notation ('/' not '\') is preferred.
Add a file from the garrysmod root. IE, if you have /garrysmod/sound/mycoolsounds/awesome.mp3, you'd use the following command:
ulx addForcedDownload "sound/mycoolsounds/awesome.mp3"
Never, ever have /addons/<mod> in addForceDownload! If you have something like addons/mycoolsoundpack/sound/mycoolsounds/awesome.mp3", you'd use the same command as above.
If you're using sv_downloadurl (if you don't know what it is, ignore this bit) then you'll need to stick what you're forcing to download in with the rest of the sv_downloadurl resources, using the same folder format.
How do I use playsound?
Format for playsound: "ulx playsound <file>"
Start the playsound with "sound" as root, so to play an explosion sound, you'd do this:
ulx playsound "ambient/explosions/explode_1.wav"
Added those to FAQs
