Author Topic: Command redirection  (Read 6744 times)
Offline Zealot
Command redirection
« on: January 21, 2019, 05:02:30 pm »
Hello.  I am trying to fix this script so that when the player uses the command "noclip" it redirects it to "ulx noclip".  I thought I had it at first, but it doesn't work.  Can anyone tell me what I may be doing wrong?
hook.Add("ULibCommandCalled", "PreventTheNoclip", function(ply, cmd, args)
if cmd == "noclip" then
return ply:Team() == TEAM_MODERATOR or ply:IsSuperAdmin()
ply:ConCommand( "ulx noclip" )
end)
Any help would be appreciated.
Offline BlueNova
Re: Command redirection
« Reply #1 on: January 21, 2019, 05:12:49 pm »
Without doing something other than a quick read, you have it returning before you have the player run noclip. So the hook will stop. Maybe just replace the return statement with an if/else statement?
« Reply #2 on: January 21, 2019, 07:44:06 pm »
Will standard server/client console command "noclip" trigger ULibcommandcalled?
noclip is a standard server function, not even part of ULib.
I imagine, it's possible, since we hook into ALL hooks with a priority system, that we might see it.
I'm not sure that's intentional though, and wouldn't expect ULibcommandcalled to be called.
(Oh, and BlueNova, nice to see you here)
EDIT - In addition to BlueNova's suggestions, you may have better luck with the GM:PlayerNoClip hook.
« Last Edit: January 21, 2019, 07:48:58 pm by JamminR »
Offline Zealot
« Reply #3 on: January 22, 2019, 07:33:23 am »
Hello.  I am not currently at my computer, but do you all think this would work?
hook.Add("PlayerNoClip", "PreventTheNoclip", function(ply, cmd, args)
If table.HasValue({TEAM_MODERATOR} ply:Team()) or ply:IsSuperAdmin()
end)
Let me know what you think.
Offline BlueNova
« Reply #4 on: January 22, 2019, 08:58:53 am »
end)
Well unless TEAM_MODERATOR is a table full of teams that would classify them as staff then probably not. You'd be better off by something closer to this...
  1. if ply:Team() == TEAM_MODERATOR or ply:IsSuperAdmin() then
  2.      -- blah blah blah
  3. end
Offline Zealot
« Reply #5 on: January 22, 2019, 11:20:32 am »
  3. end
You misinterpret my table check.
But regardless, I think I have a final version for the script.
hook.Add("PlayerNoClip", "PreventTheNoclip", function(ply, isallowed)
if !isallowed then
if table.HasValue({TEAM_MODERATOR}, ply:Team()) or ply:IsSuperAdmin then
                ply:ConCommand("ulx noclip")
if isallowed then return end
end)
I have not tested this at a computer yet.  I am on a work laptop.
First, there was the problem with the hook.  PlayerNoClip definitely looked like the hook I was looking for, so thank you for pointing me towards that.  Second, the way I was addressing the function would not work with the PlayerNoClip hook.  That has two identifiers:
player, and IsNoclipAllowed.  Therefore, I changed it so that if noclip is NOT allowed then we initiate the script.  However, if it is allowed, we return the script.
Again, I have not tested this out.  I will test it when I get home.
