Author Topic: Question  (Read 7701 times)
Offline antahz
Question
« on: July 03, 2019, 12:30:47 pm »
Hello, im making a script, what is the name of the cloak function? Example: "if ply:IsCloaked then"
What is the name of the cloak function?
Offline Timmy
  • Code monkey
Re: Question
« Reply #1 on: July 03, 2019, 07:54:55 pm »
There is no cloak function in the GLua standard library.
If you have ULib installed, you can use ULib.invisible in your own scripts.
This is how ULib makes a player invisible: https://github.com/TeamUlysses/ulib/blob/v2.63/lua/ulib/server/player.lua#L363
Checking if a player is cloaked by ULib:
if ply:GetTable().invis then
  -- cloaked
  -- not cloaked
Edit: clarification :P
« Last Edit: July 03, 2019, 09:54:54 pm by Timmy »
Re: Question
« Reply #2 on: July 03, 2019, 08:34:28 pm »
Ulx use of it
here
« Last Edit: July 03, 2019, 08:36:41 pm by JamminR »
