Author Topic: Users do not see chat echo of their message to admins  (Read 6020 times)
Offline TwInKiEmAn
« on: August 26, 2019, 06:53:36 pm »
When a user sends a message to admins using @, it doesn't show the message they sent to admins in their chat. How can I fix this?
Re: Users do not see chat echo of their message to admins
« Reply #1 on: August 26, 2019, 07:07:50 pm »
Make sure you don't have echo mode = 0
Offline TwInKiEmAn
« Reply #2 on: August 26, 2019, 07:36:38 pm »
Ulx_logecho is set to 1, all other commands echo properly, if you have the see asay  command which I don't want to give to users you can see the You:To Admins echo but users and no access cannot see it.
« Last Edit: August 26, 2019, 08:43:05 pm by TwInKiEmAn »
« Reply #3 on: August 27, 2019, 06:30:04 pm »
logEcho is case sensitive.
Check your <server>/gmod/data/ulx/config.txt and ensure "ulx logEcho" has 1 or higher.
If so,
Do you have a custom chat box?
Do you have a mod that intercepts "@" as a command?
Can users use console "ulx asay test" and see it?
Are there errors on server or client console when trying?
Is the person that's been testing muted/gagged?
Any one of the above could be breaking it.
Asay by default attempts to show the calling player say it to others, no seeasay necessary.
